Question about Garden
Ariens 8hp Formula rototiller with tecumseh engine- will not start.. have checked spark plug... gas was drained last fall. troubleshooting tips please
  • 3 Answers
Well you should really cheek your spark to see if you are getting spark by using a screw driver in the spark plug agents the metal and see if their is an arc from the points
Posted on Jan 16, 2011
I have a 1996 Ariens ST-24 snowblower that is hard starting. When it does start it runs just fine. The Tecumseh engine has a primer and I run synthetic oil, 5W30 Mobil 1 and use non-oxy gas with Sea
You could have a hole you cant see in the primer or line to the carb. They vibrate and rub. Make sure you DONT use eco gas. This will turn your gaskets to trash in one summer of not using it. Lastly dump out the old gas and start with new. Snow blowers are famous for condensation building in the tank. Hope I helped
Jan 13, 2015 | Cars & Trucks
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
How can i get engine started
Make sure the spark plug is connected
Use only highest octane gas
throw out /drain any old gas from last year
check and add oil
change the spark plug
clean the air filter or replace it
check that fuel injection lines and port holes are not plugged
if that does not work go to dump and get a new one cheap from discarded mowers that had a cheap broken deck.
Aug 16, 2014 | Tools & Hardware - Others
Ariens 1024 snowblower start
When engines set for the season with gas in the fuel system, they often form a varnish like substance that will block fuel jets, or make a float stick in the carburetor, or even seize up the throttle shaft.
You might try taking out the spark plug and pouring a partial teaspoon of gas into the spark plug hole. Screw the plug back in, connect the wire, and try it again. If it fires, you know it's a fuel problem. Sometimes that's all it takes to start it. If it does, I would still dump the old gas and add fresh gas along with some Seafoam or other brand of additive. If it's bad, you may have to have the carburetor rebuilt. In any event, with the poor quality of gasoline now days, you almost have to add Seafoam, or Stabil, or a similar additive at the end of each season to protect the fuel system.
Just a note .... I'm not familiar with your particular blower, but equipment with Tecumseh engines are very prone to those problems. Tecumseh carburetors usually require rebuilding or replacement before any other brand.
Ed
Dec 14, 2013 | Garden
Wont start, have cleaned the carb, new filter, new spark plug. removed plug and grounded. Very tiny little sparks, not real single snapping spark. Any idea of what could be the problem? Ariens model...
I believe you have a timing problem. Do you remember hitting something hard with your blade? I would say you have sheared your timing key. Order of repair : remove top cover to engine, this may involve gas tank, gas line, oil filler tube. Remove flywheel nut, remove flywheel. Timing key is the small key between flywheel and crankshaft. Timing key may just be dented but it will need to be replaced. Bring it with you, Tecumseh has a few different styles of key depending on engine and year.
GOOD LUCK.
Jun 12, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Sep 22, 2009 | Garden
Despite changing the sparkplug and proper choking, etc. no start
The most likely culprit is a clogged carb - a very common problem indeed on Tecumseh motors. Pull the carb off, open it up, spray everything with cheap carb cleaner (especially the bottom "bolt" that hold the float cover making sure it sprays out of at least two sides as that "bolt" is also the jet), make sure everthing lines back up as you pulled it apart and now try to start it up again! Bet it works, I see it all the time on small engines left with small amounts of gas in the system. Good luck, and I hope that gets ya runnin!
Mar 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
404 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
