Question about Epson Aculaser C1100 Printer
Aculaser printer says servic e required e357 and stops I've rtied just turning it off for five minutes but it does the same again
5 Suggested Answers
Inky
  • 691 Answers
SOURCE: Epson Aculaser C1900
The Cleaner Pressure Flapper Solenoid it dead or dying. You can try moving it by hand to see if you can prolong it, but basically it needs a new one. Its a job for an engineer really.
See the image below for it's location.
Posted on Oct 13, 2007
Inky
  • 691 Answers
SOURCE: Epson Aculaser C1100 Printer Problem service required e511
Errrrmmmm, how about you tell us what the problem is.
Bloke walks into the doctor surgery and says "Doctor, help me I'm ill" the doctor asks "What is wrong with you?" to which the patient replys "You're the doctor, you tell me"!
Posted on Jul 23, 2008
tigertail
  • 163 Answers
SOURCE: Changed the photoconductor unit on epson aculaser c1100
Hi, the E511 is caused by the printer not "sensing" rotation of the PCU drum & transfer belt (TRO Sensor error). It could be the PCU was faulty. First thing to try is to open the top cover and remove the PCU. Be careful not to expose the drum to bright light, avoid touching it if possible and be very careful not to scratch it. Using thumb pressure at the edges of the drum check it rotates. On the underside of the PCU is a little cut-out window, rotate the transfer belt until you see a little silver square appear. Give this a good clean with a soft cloth. Inside the printer you will see a little sensor sticking up (TRO Sensor) that aligns with this cut-out, give this a clean too. Hopefully your problem is now fixed.
Please take a moment to rate this solution, thanks.
Posted on Apr 02, 2009
SOURCE: error message on epson aculaser c1100, service
replace rom
Posted on Aug 04, 2009
PRINTER SHOWING 'SERVICE REQ E300'
Sadly this is a serious error requiring a replacement Laser Unit - if you are lucky. It may also be a system board error that is falsely reporting the error.
This printer is likely to be beyond economical repair.
Aug 22, 2012 | Epson Aculaser C3800 Transfer Unit
Coming up with E357 error, what is it? how do I fix it?
It's potentially solved, I just haven't done it yet! Epson Customer Support told me it was the fuser out of order and I should just remove the fuser (utilising the green tabs and maybe having to use a screwdriver) then re-install it. Will know if it works once I complete the action.
Jul 10, 2009 | Epson Aculaser C1100 Printer
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Epson Aculaser C1100 Printer suddenly stopped printing
To my knowledge Error Code E511 refers to photoconductor and/or its associated components. It is possible that:
  • the photoconductor requires a bit of cleaning and to be reseated snugly;
  • the black rubber conveyor (transfer) belt inside the photoconductor moved away from its path;
  • the silver square reflector on the transfer belt needs cleaning;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
SERVICE REQ. C0082
C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
Jun 09, 2008 | Epson Aculaser C1100 Printer
Service req E527 error
xfa podria decirme k parte de sensores o motor esta para cambiarlo en mi impresora epson aculaser C1100 el service req E527, y no se puede hacer nada, ayudame xfa mi correo es dayeralb3@hotmail.com, de antemano le agradesco su gentil ayuda
dayer...
Mar 05, 2008 | Epson Aculaser C1100 Printer
Check paper size message even though paper size is correct
Make sure when you send the print job, that manual duplex options are NOT selected.
Jan 16, 2008 | Epson Aculaser C1100 Printer
Sep 17, 2007 | Epson AcuLaser C1900 WiFi Printer
Epson aculaser c 1100
What was the service error code It would look something like Service Required E510. This show on the panel and/or in the status monitor
Without this code all we know is your printer has something wrong with it.
Sep 14, 2007 | Epson Aculaser C1100 Printer
Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
Epson Aculaser C1100 Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
