Question about Goodman GMS90703BXA Heater
Turns on but no heat
Starts up but cant se fames inside when it starts anymore then just shuts off. Is there a pilot light that might have gone out?
    Scholar:
  • 45 Answers
Your furnace is equipped with HSI(Hot Surface Ignition) ignition system. There are also many safety features incorporated in these furnaces. When the thermostat calls for heat, the inducer motor comes on. This feature is called "pre-purge". Pre-purge circulates fresh air or combustion air into the furnace and pulls it through the heat exchanger and the secondary heat exchanger and out throught the pvc exhaust pipe. This takes anywhere between 5 and 15 seconds. lets say there is a restriction in the exhaust pipe(example: bird, mouse, squirrel, tennis ball), there is not enough push behind these inducer motosr to push anything but exhaust fumes out. There is a pressure switch connected to the inducer which will not close if there is any sort of blockage within any of the parts listed above. We have had a terrible year this year with pressure switches sticking. You can hook up a manometer to the pressure switch hose to see what type of pull you are getting. There is usually a pressure rating on the pressure switch.lets say the pressure switch and ventor motor is fine. That would lead you to the ignitor. Pretty common for these to break. If it is not the ignitor then you may have a bad board. There should be a printed circuit board in the bottom compartment of the furnace with a LED on it. You should be able to get a diagnostic flash code off that board. Let me know what you see or what you found out.
Posted on Jun 05, 2010
  • urplsor534 Apr 02, 2011
    also check the vacuum line to the pressure switch, under continuous vacuum and older line may collapse and cause a myriad of problems (from a bad pressure switch to continuous cycling as the vacuum decreases and hose opens up). Cutting the hose back a little to get rid of kink may work but, replacing the hose is best remedy (pressure switch is a snap to check out). William Wittenmyer, AS (Electronics), tsgt, usaf retired.
  • 674 Answers
From what I saw when I googled you furnace it has a hot surface igniter. It only gets hot when it's time to light the furnace. You should be able to see it glowing red when the furnace is trying to light. The furnace has a safety feature which shuts the gas valve when it doesn't detect a flame to prevent gas build up in the furnace. There are other safety features also. If the draft inducer motor isn't running the gas valve won't open. Overheat switches some of which have to be reset manually. Adjust the thermostat until it calls for heat then observe what is or isn't happening in the furnace. It will go thru a purge cycle first. The draft inducer motor will run to do this. After the purge the hot surface igniter should get hot a glow, then the gas valve will open and the burner will light. Let me know what you find.
Posted on May 04, 2010
Pilot light on 1954 wedgewood gas stove burns too hight how to adjust
There are small screws on the manifold that control the pilot fame. They could be accessed by removing the top panels or sometimes they can be accessed from the front , Some of the front panels snap off. remove the burner tops and trace the tubes back to the valve manifold and you should see a screw on a small valve. Turn these and the pilot lihght should go up or down.
Oct 01, 2014 | Kitchen Ranges
I have a whirlpool hot water heater and the piolit light wont stay lit can you tell me wher the screen is to make sure its clean?
Not sure what screen you refer to, but the simple fix, assuming you have done all the correct pilot re-light procedure's, the cheapest part to try is a Thermocouple, easy enough to try it DIY.
Jun 04, 2014 | Water Heaters
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
How do I change the pilot light as it is not working anymore.
It won't be the pilot light, It will be the gas valve control, if the pilot light actually lights but the burners won't light,, then you need to check the thermocouple , its that little round thing that sits inside the flame of the pilot light, and has (usually) a copper tube that runs back to the actual gas valve, If its gone bad, the signal to the gas valve is lost so the gas never gets released so nothing lights
Jul 07, 2011 | DeLonghi DEFSGG36-SS Gas Kitchen Range
No Hot Water
Well, let's start the trouble shooting process with trying to get the pilot lit...
Have you removed the cover at the bottom of the heater?-- Can you see an pilot light inside?
If not, Can you try lighting the pilot-- and noticing how the pilot flam heats the little ThermoCouple (TC)?
Note: In order for gas to flow thru the main control valve, the pilot light has to be heating the TC-- to generate a voltage, that in turn allows the main gas valve to open.
Do you need help in getting the pilot light lit?-- do you understand the need to hold down the start button, until the TC gets heated up?
Let us know what you find
Mack B
Jan 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a raypak 2100, looks like its a 1997 model (seriel# starts with a 97). Unit starts up fine, runs for about 5 minutes and shuts off. It's not close to reaching temp, and I get get it start back up...
If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Sep 19, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
No heat
It can be both the heat fuse that gone or your pilot light has gone out, check to see if you see a flame while it is functioning, to do this turn on your dryer and watch in the dark so that you can actually see the flame coming on and off or check behind the little door that houses the pilot light to see if you see a flame if no flame relight, this should start your dryer producing heat again
Jun 22, 2008 | Sharp R-353 Microwave Oven
Goodman GMS90703BXA Heater Logo
333 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
