Question about KitchenAid K45SS Classic Stand Mixer
My mixer is about 15 years old works well except
My mixer is about 15 years old works well except it growls at slow speed
  • 235 Answers
Hi BCPSBT. You say your mixer growls at slow speed. It could be that it’s time for an oil (lubrication) change. KA packs your mixer’s transmission with enough grease to ‘last a lifetime’, but depending on the age (in this case a middle-age appliance) and usage (you don’t indicate) of your mixer the grease breaks down into its constituent parts: oil and additives. Over time, the additives will thicken and provide less lubrication to the transmission gears and this is probably what is occurring now.
If you are DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you are lacking one, you can download it from the KA website http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and select “Consumer” for User Type, then enter the 6 character Model Number, in your case use K45SSW select Parts List (1) and then check to see it this matches your mixer model.
Turn to pages 4 & 5 for the disassembly and reassembly of your mixer, along with all the parts. For starters, you should consider reordering the gasket (Illus. No 19) and O-ring (Illus. No 34). With the mixer apart and transmission exposed, you should be able to confirm how well the lubrication grease is distributed and doing its job. Also, once apart you can check for any other unseemly wear and tear on the gears, including the planetary and agitator shaft gears.
When you re-grease the gears and assemblies, you should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
As far as parts go, here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites, their excellent pictures, descriptions, and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on May 06, 2010
I have a 40 year old Kitchen Aid mixer, Division/Hobart. I just finished with some dough and the mixer sound like it was growling,slowed down, turned it off, does not work now
There can only be three things:
1. Brushes needs to replaced;
2. Rotor is used out;
3. wheels can be use out;
Open machine and look at these three components. First one is easy fix, you take one out and replace it with another, others two are cul de sac, I am afraid.
Apr 04, 2016 | Food Mixers
My 325 watt, 5 quart artisan stand mixer won't work on "stir" speed. All other speeds work fine, but when I put the switch on stir, I just hear the motor whining like it's trying to work, but...
By not working to mean that the planetary gear wont move? or does it just make a weird noise when it is on a low setting? If the gear is completely stripped the unit shouldn't run on any speed regardless if there is mixture in the bowl or not. Since I can't see the mixer I would say that there might be a slight tear in the gear which would only allow the mixer to get stuck on a slow speed where as on a high speed it is running fast enough to skip that particular tooth. I understand that the mixer is brand new but when it comes to mixers you can strip a gear right out of the box depending on the consistency of the batter you are mixing. If the machine is under a year old it is under warranty and you are allowed free service by an authorized repair center in your area.
Nov 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
When the mixer is turned on, you can here the inside going, but the outside part does not turn
Sounds like a problem we had years ago. We put too much pressure on the motor by mixing a very thick dough for cookies. It stripped the "gears" and couldn't be used on slow.... it would instantly go to the fastest speed. We had to take it to a reputable appliance store that does repairs on KitchenAid products. I'm still using mine and that has been 15 years ago. It still works great!!
Aug 29, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
Aug 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid K5AWH Stand Mixer
Kitchenaid 250 watt. Speeds up and slows down on its own?
Call the Kitchenaid service number (1-800-541-6390 in the U.S.). As your unit is still under warranty, and they are very proactive I'm sure this problem will be readily resolved.
Mar 01, 2009 | KitchenAid K45SS Classic Stand Mixer
Sunbeam 2346
I just did it. Get your digital camera and take pictures along the way so you'll know how to reassemble it.
On the front of the mixer, there is a chrome Sunbeam sticker. Use a pocket knife, slide it under the sticker and pry/peal it off. Then you will see a single screw that goes into the guts of the mixer. Unscrew it and remove the front of the mixer. You'll then see two screws that keep the top of the mixer on. Remove those and you can undo the top housing.
You take off the back of the mixer in a similar manner. Use a screwdriver to pry off the chrome cap on the back, then remove the single screw and the speed control will come off.
The gear box just above the blades is a potential area for the growling. It is pewter colored metal held in place by four screws. Clean out the old grease and replace with new (NOT oil, grease, like axle grease or lithium grease).
Use a toothbrush to get the old dust and flour off the innards of the machine. I also used a can of compressed air to blow it out and sprayed the electrical contacts of the motor with WD40.
Mine works like a champ now. Took about an hour.
Dec 13, 2008 | Sunbeam Heritage 2346 Stand Mixer
Mixer speed turned erratic!
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Nov 22, 2008 | KitchenAid KSM50PR Professional Series...
KitchenAid K45SS Classic Stand Mixer Logo
252 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
