Question about HP LaserJet 4700 Printer
HP Laserjet 4700, trouble printing to custom size paper.
HP Laserjet 4700, firmware version 20090914 46.036.1, won't print on custom size paper. Paper size has been built in the driver software and assigned to "tray one manual feed." One the printer itslef tray one is assigned "any size, any type" paper. Printer grabs paper from manual feed but always tries to print as if it were letter size. This has happened repeatedly with different sizes. Any one had similar problems?
4 Suggested Answers
  • 4402 Answers
SOURCE: HP LaserJet 9040mfp All-In-One... Problem
You first need to run a configuratin page from the infromation menu on the printer. It will tell you what size and type paper the printer thinks is in tray 2. If that does not match what is actually in the tray (size) then you may have a issue with the paper size switches on the right inside cavity of the paper tray. If the switches, there is a samll pca board behind the black cover with the 3 metal springs. That board is the same for both trays 2 and 3 so you could switch the boards to see if that is the issue. It could also be as simple as the paper tray bar not aligned correctly and the easy way is to switch trays 2 and 3 and see what happens. The type setting which is inputed at the printer if not matching the job will cause the paper to not be drawn unless that type is asked for. Example if someone changed the type to preprinted and you do not ask for preprinted it will never draw from that tray. Hope this helps.
If tray 2 & 3 have same size/type, will pull paper from 3 until empty. Make sure that the tray selection (or paper type) in the printer driver or software application is set correctly. (The printer driver and software application settings override the printer control panel settings.)
Posted on Jan 09, 2008
  • 85 Answers
SOURCE: HP Laserjet 3050, need to press ok each time printing
did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
Tray which printer prints from.
Just had this problem and stumbled upon how to fix it. Check the guides in your tray 2. Our back guide was slightly off of the proper spot for letter size paper. This was causing the printer to think the tray had a custom size of paper in it. Your document is probably trying to print on letter size paper and when it doesn't think the paper is in there it switches to tray 1.
Apr 08, 2010 | HP LaserJet 4700 Printer
How to print a custom size paper on HP Laserjet 2550 I used to be able to print pretty much any size of the paper with this printer, but now, I can not even find the ''Custom'' for the paper size in the...
USe the Page Setup in the word processor. It is how the word processor uses the printer that matters. There you will find Custom and you can specify the page size.
Nov 17, 2009 | Office Equipment & Supplies
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Officejet 7210 puts odd sized print jobs on hold
check to see if there is a custom size option on the page setup on the print job. that might work.
Jul 31, 2009 | HP LaserJet 2840 Printer
HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Jan 20, 2009 | HP LaserJet color laser printer
Thank you for taking my question: HP laserjet print using Vista
go to printer propeties and check paper size ther'l be a custom size click on that n feed what u wnt
Dec 11, 2008 | HP DeskJet 880c InkJet Printer
How to print on custom paper
Worked it out in the end -
1. In XP classic view, Right-click on Start, Settings, Printers & Faxes
2. In the Printers & Faxes window, click on File, Server Properties
3. With the Forms tab selected, check the Create a New Form box
4. Enter a name for the new form in the Form name: field
5. Enter values for the paper size and margins
6. Click the Save Form button
That's it - the new custom paper size should now appear in your print dialogs. hth.
Sep 23, 2008 | HP LaserJet 2550L Printer
Print from MS Word 03 & e-mail to P2015dn trouble
This could be due to incorrect paper size. We have letter as default paper size in the driver, however, A4 paper size into the application.
Please try the latest drivers (Universal Printing Driver) from
- Nikhil
Apr 14, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 4700 Printer Logo
361 people viewed this question
Ben Johnson
