Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Briggs stratton 500 series lawnmower will not start, Spark pluge & filter ok
smjdragonfly
  • 79 Answers
SOURCE: have Bolens series 080 22
When you take off the carburetor initially, you should change the gasket if it tears or just old looking, your problem is in the carburetor, probably. Take it apart remembering where the parts go. There are some diaphragms or gaskets and screens on some, tiny jets and such that are inside the little "bulb" or bowl, that can usually be taken off with a 10mm wrench. They also have little fiber gaskets and a bowl gasket or o-ring that must be in great condition with no trash. Clean off with starter fluid or carburetor cleaner.
Posted on Jun 18, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
freetek
  • 5568 Answers
SOURCE: briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Posted on Aug 20, 2009
  • 41 Answers
SOURCE: my briggs and stratton 550 series lawnmower will not run
Could be float in carb.sticking.Take carb off & apart.Put float in water to see if it floats.Check float by shaking next to ear.If you hear any sound,you need a new float.
Posted on Aug 29, 2009
  • 143 Answers
SOURCE: Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Posted on Apr 25, 2010
Testimonial: "very helpful. will follow instructions. Thank you"
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
3.5 hp Briggs & Stratton won't run unless I pour gas into carb
This sounds like a problem with the suction. If the air filter is clean then it will need new carb gaskets. There may also be an issue with the pressure being created by the engine.
Jun 18, 2014 | Briggs & Stratton Briggs Stratton...
Briggs and Stratton 300 Series lawnmower will not start.
many things can cause this
shear key damage will throw it out of time and will not allow it to start.
diaphragm in the carburetor may be leaking, or fuel filter may be plugged.
spark plug may have failed, magnetron coil may have failed also
(no spark)
Sep 11, 2013 | Garden
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
17.5 hp Briggs & Strattion has no spark
unplug the harness to the engine should be a 5-6 wire give or take then crank it look for spark if you get spark that way check the safety switches if no spark change the coil
Apr 24, 2012 | Briggs & Stratton Briggs Stratton...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
I hev a briggs & Stratton 5.25hp lawnmower and
I would need the engine numbers to tell ya what to do for sure. It sounds like the engine is too full on oil. Check oil levels carefully.That engine capacity is only 1 pint/16 to 20 oz's ALSO you friend may have cleaned under your deck and turned the mower with the aircleaner DOWN. That causes oil to flow from the crankcase into the air cleaner and muffler.That aircleaner is a dry paper and should not have any oil on it, If this is the case then the oil accumulated in the muffler will burn off in time. Oil soaked paper aircleaners will cause this engine not to start.IT CANT BREATH
Oct 21, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
1,051 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
