Question about Kitchen Ranges
No cooling, i unplugged for several hours, and the tries to come on for 10 to 15 seconds and the shuts off for several 5-10 mins and tries to start all over again. the fan in the freezer and the outside fan in the bottom works. What is happening?
  • 1 more comment
  • mvl777 May 04, 2010
    this refrigerator has been down and not working for over 24 hours. Just tried it again and the compressor tries for 10 to 15 seconds then shuts off then retries again after a few minutes. Is there an automatic defrost timer on this box if so where and could this be the problem?
    frigidaire side by side model .plhs267zab6"
    This refrigerator has been turned off for more than 28 hours. I plugged it in and the compressor tries for 10 second turns off the 5 minutes later it tries again then clicks off. Could this be a auto defrost timer going bad? can i manually turn it off? Where is it located?
    you got the answer when I gave you the symptoms
    great 5 min fix
    President:
  • 949 Answers
Sorry to hear you are having trouble with your refrigerator. From the description you have given here, it is most likely the start relay for the refrigerator that has gone out.
To check this, you will need to pull the refrigerator out and get behind it. Unplug the cord from the wall and and remove the lower rear panel. Behind there is a compressor, it is black and about the size of a bowling ball, this is the device you are hearing trying to start. On one side of it is a plastic cover with wires entering it. Remove that cover and that will expose the start device in question. If you remove wires from the components be sure to note where they came off, I like to take a digital picture so I remember. The first component that comes off is the relay, if it rattles it is bad.
If you can send me the complete model number from the tag on the refrigerator I can help identify the part number you will need to fix it.
Posted on May 04, 2010
  • 732 Answers
Mvl777, If the condenser coils are clean and dust-free, then unit may need to have compressor replaced, or at least inspected by a qualified HVAC appliance technician to determine cause of "shutdown" !! When was last time unit's condenser coils were cleaned with a vaccum cleaner??? Are the automatic "defrost" heating coils working? Your unit may need to be emptied out and left open overnight (defrosted) to completely defrost unit. 12fixlouie
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Royal dometic. not sure year or model. started cooling several days after power connected..auto defrost kicked in second time there was frost buildup and now neither fridge or freezer will get cold..have...
When you feel cooling unit from outside behind cover and unit is on for a couple of hours min, does it feel warm, hot? describe any other things you notice please.
Apr 09, 2013 | Refrigerators
2009 Nissan Altima A/C blowing cold for 20 min. then blows hot
if the ac system is very strong and there a lot moisture in the air the a'c evaporator core will freeze up and stop air flow threw the cold core only use the recuiculation part to cool the car down about 5-10 min the turn the recuit off
Aug 22, 2012 | 2009 Nissan Altima
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
I don't know if it's my linksys 5 port router or
Could be over heating let it cool meaning complete shut off unpluged 20 mins for all heat to removed. Then check how long it stays on. If it last more than a few mins it is over heating. You need to try to get all dust out of it and try it again. If this time the link is lost after a few mins or hours its was over heating. Also at this point it could be a bad component over heting and a new router is need.
This could be one of many problems good luck.
Sep 09, 2009 | Linksys EtherFast 10/100 16-Port Workgroup...
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
