Question about Keurig Platinum B70 Coffee Maker
Coffee grounds in the cup
I have purchased a new keurig platinum machine. The first cup that is brewed always has coffee grounds in it and it is not filled to the top despite making sure to select the right size mug. The second cup of coffee is usually brewed perfectly. Any ideas?
    Sniper:
  • 92 Answers
Since you said usually... I suspect the rubber seal that surrounds the top needle is not seating well...
you can verify this by making a beverage with a k-cup and, just before the water starts, add a little hand pressure to the K-cup arm pushing down a little bit... not hard...
If it consistently makes a good beverage, then we focus our attention to that piece of the brewer...
when the consistency of the water changes, it tells me to look for leaks or unusual percolation of water...
you can verify the K-cup holder is ok... but another way to simulate the hand pressure is to put a shim of some sorts under the lip of the k-cup... like the thickness of a couple sheets of paper under the rim... not the actual k-cup... but the k-cup holder... raising it up a smidge is the same as the slight hand pressure...
I would look to see if the rubber seal has come loose around the top needle....
Posted on May 06, 2010
Keurig Platinum B70 Coffee Maker not de-scaling properly?
Purge and blow out the lines. Debis is in tubes and ports.
Jan 12, 2012 | Keurig Platinum B70 Coffee Maker
I purchased a B70 Keurig brewer less than a year ago and now it will not pump water.
That happened to mine. The pump broke. They sent me a new one at a "discount" but now after 2 months I have issues with this one. Can someone PLEASE make a coffee machine that will work? Preferably one NOT by Keurig that uses the K cups and the K cup you can use your own coffee in?
Oct 22, 2011 | Keurig Platinum B70 Coffee Maker
Does not brew runs but no coffee . Always used bottled water, cleaned with vinegar 3months ago. While trying to brew one of the cup size symbols stays lit ( not the size we have it set at)s
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 03, 2011 | Keurig Platinum B70 Coffee Maker
When brewing a cup of coffee,the maker is not brewing a whole cup....and on the screen it said de-scale
heatman101
Apr 24, 2011 | Keurig Platinum B70 Coffee Maker
My Platinum Keurig says it is ready to brew but nothing happens. I have cleaned out any coffee grounds.
My B70 has worked good for about 6 months. Lately it won't brew a full cup of coffee or water for that matter. I have run Limeaway, and also vinegar throught it but nothing works. It seems to me the pump is too weak to make coffee before an apparent time-out occurs.
Dec 15, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum is clogged
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
270 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
