Question about Hitachi Performa CP-RS55 Multimedia Projector
Power supply failure
This projector was dead (no power) i get the transistor (3451)short i replace another transistor (k 2996) now the power ok but i get the lamp red led.
why these transistors always gun.
thanks
  • 563 Answers
I've asked the exact same question to a factory engineer at a well known manufacturer and they could'nt aswer this either
Posted on Apr 02, 2008
SOURCE:
Hitachi TV model C21-rm25s-192 power supply transistor and fuse blow off just after replacement. other components of the power supply seem to be ok. what should I do?
The SMPS - power supply is critical of the generated frequency , load trip and high voltage. So if the power transistor has blown then you must check the reason for the failure before the new one is put into the circuit. Check the DC voltage, check the rectifier, storage capacitor and the frequency oscillator. check for short in the SM tranformer , feedback optocouplers or a possible short in the main circuit.
Please check the link below for help:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 08, 2011 | Televison & Video
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
Dec 31, 2008 | Blaupunkt PCA460 Car Audio Amplifier
I have an audiobahn A8000t amp with the protection light on
Note:
Dec 30, 2008 | AudioBahn A8000T Car Audio Amplifier
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
Dec 30, 2008 | Visonik V4208 Car Audio Amplifier
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
I need the electrical diagrams to repair my rear projector model 55PW9383/17F Chassis DPTV340. Failure: no power on
You prob do not need a diagram to figure out this problem. If it powers on, then powers right back off again, then you could have a serious horizontal transistor short. If the TV is just dead period, you can try to replace all the large capacitors around the power supply area. A bulging top or leaking around the bottom are nice features to identify problem caps.
Nov 14, 2008 | Philips Televison & Video
Snoy model KV-21GMR1
check secondary voltage first and look for short.if you replace the regulator strs6707 you replace also c623 220uf/16volts
Sep 24, 2007 | Emerson TC0918 Television
Hitachi Performa CP-RS55 Multimedia Projector Logo
112 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
