Question about Sony KP-53XBR200 53" Rear Projection Television
Fuzzy picture moved the tv and the picture went fuzzy.
  • rickfera May 05, 2010
    The picture looks fuzzy,like an old tube tv. color faded. thanks, rick
  • Larry  Dillon
    Larry Dillon May 11, 2010
    does it look fuzzy or likea3D picture?? techman
    President:
  • 3,130 Answers
Have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
Posted on May 05, 2010
Testimonial: "Thanks I'll try cleaning and let you know.. I never thought of that.."
  • Larry  Dillon
    Larry Dillon May 17, 2010
    does it look better now????
    Techman
Fuzzy picture
Try moving the hdmi cable around, disconnect it and reconnect it. Try using a different video source.
Oct 20, 2012 | Hannspree Televison & Video
Picture gets fuzzy especially the writting on 2000 Sansui tv
This could be multiple things. If the fuzzy picture is on your regular cable channels and the tv is hooked up directly to the cable then it is a signal issue. Your cable signal is probably too low because it is either split too many times, a splitter went bad, a piece of cable went bad, you have RG-59 cable rather than the much better RG-6 cable. Another solution is if there is a vcr hooked up, the cable jack on the vcr could have gone bad, the vcr power could be on which will cause a fuzzy screen. If you have a vcr try to bypass it and hook directly to tv. If that fixes you problem then it may be the vcr or the wire from the vcr to the tv. If you have no vcr then I recommend buying a cable amplifier and hooking it up. This is a band-aid solution but it could work long term if it's just a matter of weak signal. If that does not fix your problem I would recommend calling a cable professional to evaluate your problem. Could be the line from the pole to your house or any of the wiring in your home.
Jul 10, 2010 | Panasonic CT-32SL15 32" TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Recorded play back is fuzzy
MOST LIKELY the RF out put signal is the same as a local tv chanel 1) try menue change rf output suggest rf 68! OR connect av leads (red white yellow)from the output of your vcr and connect the other end to an Av input eg AV1 on your TV use tv remote to select the AV input
Apr 21, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips 34pw9818 fuzzy screen
Inside the set you should see a large part with a red wire coming out the top. That is the flyback transformer. There will be 1 or 2 controls on the back of it. One should be labeled screen and one focus. Carefully adjust the focus one until the picture is again in focus. Please note that in that area are high voltages (33,000V) that can be dangerous. Be careful where you touch. IT is best to have a mirror so you can see the picture while adjusting the focus control.
Dan
Feb 04, 2009 | Philips 34PW9818 34" TV
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The picture on my tv is fuzzy
Check your connections Inm the Back of your Tv and Also see If your VCR got turned on By Mistake....
Jul 18, 2007 | Insignia IS 20" TV040919 TV
Sony KP-53XBR200 53" Rear Projection Television Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
