Continues from "no disc"
I have tried the cleaning disc. What exactly does the lazer look like so I know I am cleaning it correctly when I use the Q tip.....Thanks!
  • Anonymous Dec 25, 2008
    how do i clean the lens in a goodmans stack system multi player
    Master:
  • 518 Answers
It looks like a small eye. Be very gentle.
Geno
Posted on Mar 27, 2008
6ya staff
SOURCE:
My final fantasy 10 game is frozen. when i bought another of the same game i put it in the machine and it froze in the exact same place. where is the problem here?
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Jan 02, 2011 | Sony PlayStation 2 (PS2) Console
Disks skip and do not play
try putting a laser disc cleaner through the player it will clean the lazer allowing it to read correctly
best of luck
Add a comment
  • sonicboomele
  • 1 day ago
sonicboomele_0.jpgthis is what they look like the small brushes clean the laser
Reply
Dec 29, 2010 | Sony CDP-CE375 5-Disc CD Changer
Will not read the disc correctly. Once it does it plays fine, but it sometimes takes several minutes to correct the problem, and it is getting worse. I have cleaned the disc, and that does not seem to be...
you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem....
or click here to download repair guide
Dec 26, 2010 | Microsoft Xbox 360 Console
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
My phillips HTS3090 system keeps saying BAD DISC
for some reason the unit is not happy with the disc have you tried running a lazer cleaner through it? although i wonder if that will work as the words bad disc does seem to mean a lazer read problem but then it can only be either a dirty lazer or the lazer is miss aligned withch means it need s a pro service .... try cleaning the laser
Jul 03, 2010 | Televison & Video
Hi i got a Diamond DVD player DHT-5000 Home Theatre but it keeps saying disc err or no disc
it has a dirty lazer if you know how clean it by hand with ear bud and alcohol if not use a cleaning disc if still not working the lazer is out of alignment good luck
sonic boom electronics australia
Apr 21, 2010 | Yahoo Diamond Vision DVDC803-04 DVD Player
Used lens laser lens cleaner & now player won't play.
You can open the dvd and try to clean it manualy.open the dvd so you can see the lazer.take a normal earbud and wet it with normal methylated spirits and clean the lazer gently with that.the lazer cleaners hardly ever work 100%.Just remember not to push to hard on the lazer or you will brake it.gently clean and wait for lazer to dry and try again.
Feb 19, 2007 | Samsung HT-WP38 System
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
