Question about Sharp CD-BA2600 CD Shelf System
Error code 0203
I have a sharp CD-BA2010. The cd tray is not opening or closing showing error code 0203! Does anyone know the solution for this please?
  • goldfi Nov 03, 2008
    the disc doesnt open and with a eror 305 or 101
Sharp bk 1800 almıştım .3 vcd kasası açılmamaya başladı .satın aldığım zaman da aynı problemi yapıyodu servise yolladım.tamır edildi ancak uzun sürmedi aynı problem oldu.birkez daha servise giti geldi.kısa zamanda aynı problem oldu.ekranda "eror 0203" yazıyo. bu problemi nasıl çözecem bilmiyorum.sharp kalıteli diye tercih ettim.ancak memnun kalmadım.televizyonum da sharp.bana yardımcı olursanız sevinirim saygılar. imail :enteresan.3@hotmail.com
Posted on Aug 15, 2008
  • 4,234 Answers
This is a mechanical error. The mechanism is stuck and can not reset to a known condition. Look to see if a CD has slipped nad try to get it back in place. If that is not the case, it will need service as the mechanism is now out of timing.
Dan
Posted on Mar 26, 2008
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
I am getting an error Message 0306 or 0203 when trying to open the cd tray on my Sharp CD-BA150 Stereo System what can I do to fix this problem
For the error 0306, simply remove the lid of your system and clear the dust out/off of the lense and surrounding areas. (i.e. soft cloth, canned air, ect...) Hope this helps!
Jan 18, 2011 | Sharp CD-BA150 Shelf System
Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
i had the same problem. my brother took it apart and found that the belt that opens the tray was snapped. he bought a new one at radio shack and replaced it. but now there's a new error with no code. so thats as far as i can get you. sorry. =)
Dec 05, 2008 | Audio Players & Recorders
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
CD Player
Does the cd draw open an close freely? Possible it could be the cd loading belt needs replacing. Its located at the top right side below the mechanism.
Oct 09, 2007 | Sharp CD-BA150 Shelf System
CD Player tray will not rotate or open or close - no power
my cd player will open and rotates but will NOT play, can anyone help me?
Oct 09, 2007 | Audio Players & Recorders
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Sharp CD-BA2600 CD Shelf System Logo
1,000 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
