Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Gas ratio what is the gas oil ratio when mixing fuel for my chain saw?
    Brigadier General:
  • 4,088 Answers
Most saws built within the last 30 years or so can be run with 40:1 using modern synthetic saw oils. A number of late model units run 50:1. Make sure to premix the fuel and oil before adding to the saw. Hope this helps!
Posted on May 04, 2010
Chain saw motor is smoking
Hi Mark:
I'll go over the basics so please ignore what you already know.
Chain saws are 2 cycle which means the gas must have oil added. The ratio is 50:1 typically.
Chain saws are air cooled so they get HOT. They like to be kept clean, and a build up of oily sawdust is an invitation to an unwanted fire.
The chain is lubricated by a thick oil that gets put in a different tank. If you run out of chain oil, the chain will get really hot and you can actually ruin the bar by overheating it. A good rule is to always fill the chain oil tank (with chain oil) at the same time that you fill the fuel tank (with gas/oil mix)
Make sure the chain is kept SHARP. A blunt chain makes the saw work harder and causes friction which generates heat.
On a regular basis, take the bar off and clean the brake assembly and all the bits and crannies. Compressed air and solvent will make the job easy.
Chain tension should be kept snug but not too tight. I like to be able to lift the chain at the centre of the bar and have the underside just barely clear the groove in the bar.
Lots of bars have a roller at the tip and there is a fitting to inject grease. It's a good idea to use it regularly.
I think that about covers it. If you have any specific questions, send 'em on.
Apr 30, 2015 | Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
What is the oil to gas mixing ratio for a poulan SM 4018 Pro chain saw?
The ratio is 50:1 fuel to oil using fresh fuel and a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Be sure to mix in it's own container, and shake thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 10, 2010 | Poulan Garden
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need to know the proper gas oil mix for the 42cc engine
50:1 is the correct fuel to oil ratio. Be sure to use a modern synthetic oil made for chain saws, and premix the fuel and oil in it's own can-- shake the can thoroughly just before filling the saw each time. With the very lean fuel to oil ratios used today, it is important to keep the oil in suspension to prevent engine damage. Hope this helps!
Aug 05, 2010 | Homelite ZR10926 16" Chain Saw
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
My brother in-law gave me a chain saw, the 1st for...
Always premix fuel and a modern synthetic saw oil in a separate can before use. Never run a 2-stroke saw engine without mixed fuel. Motorcycles use an oil injection pump that allows the burning of straight gasoline, but no one has come up with similar system for saws. Use 40:1 ratio fuel to oil. Hope this helps!
May 20, 2010 | Garden
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
223 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
