Question about Mitsubishi WS-65869 65" Rear Projection Television
It looks a great deal like watching a 3d movie without 3d glases. The convergence is not correct. I tried to correct with a convergence back to factory settings and a manual correction from the remote. Not luck the red is 1/2 inch right of the other colors on the screen. Is this the end ?
    Scholar:
  • 70 Answers
Common convergence problems like this require the set to be repaired. Transistors are used to control convergence and they will go bad eventually and require replacement. Expect a repair cost in the 100 to 175 dollar range depending on who you can find to complete the repair.
Posted on May 04, 2010
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Looks like 3D with out the glasses
you need the phillips dptv 305 - dptv345 chassis convergence repair kit which contains both convergence ics and all feed resistors and also free installation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Wide screen t.v. picture problem
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 05, 2009 | Sony KP-51WS510 51" Rear Projection...
I have a sony wide screen projection t.v.(2003)...when i turn it on it looks like i'm watching a 3d movie without the glasses...the picture is also curved...any ideas?
Screen looks 3D
>>>Solution<<<<
Shadow on screen. Looks like you're watching a 3D movie without the glasses.
youre convergence ICs need replacement, please respond to this same post with your model number and I will post the correct ICs for your set.
Sep 04, 2008 | Televison & Video
3D Looking Colors
yes its most likely the STK392-110 ICs change both at the same time. You can get replacements at the following link with free instalation instructions.
Jul 31, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Looks like watching 3D movie(colors) and rounded
This is a convergence problem and is either bad connections on the convergence ICs or defective ICs. If you feel that you can solder, you should be able to repair this yourself. First try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These ICs are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Toshiba 57HDX82 57" Rear Projection HDTV
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
