Question about Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma iP1500: How to insert 5 springs on internal plate?
I disassembled my Pixma iP1500 to clean the waste ink absorbers.
Everything went great until I was putting it back together. I need to insert the 5 springs which sit in the white plate (tilts up and down, helps in feeding paper). But I can't find help on it anywhere. The video I was following does not show this.
Does anyone have a photo of what they should look like?
  • ghentartist May 04, 2010
    I found a Service Manual for the iP1500 online. There is a diagram of the printer parts. However, this white plate and its springs are NOT listed! They are not shown in the blown-apart reference photos.
    If you're looking at the inside of the printer, this white tray sits under the assembly that holds the printhead slider (front) and the logic board (back). The tray has white rollers just above the Platen ink absorber, and the printhead slides in front of them.
  • ghentartist May 12, 2010
    I took a guess as to how the springs should fit after examining the plate and trying several ways to insert the springs again. It seems that I got it right. Too hard to explain without a photo, though.
  • 8 Answers
I just lined up the main housing, put the 2 screws in the front (did not screw in the 3 side screws) ( tried it when the housing was off the springs would just fall down)
just slide the springs in after it is screwed in the short side fits into the white plastic you will see grooves where it lines up on the white plastic piece, the long side of the spring hooks on to the back metal hook on the other side the coil rests in the middle of the prongs
http://i945.photobucket.com/albums/ad294/seichal/ip1500%20springs/20150210_183120_zps7e85807d.jpg?t=1423531107?143
Canon Pixma iP1500: How to insert 5 springs on int - 2_11_2015_1_24_09_am.jpg
canon-pixma-ip1500-insert-5-springs-inte-pj1gq0ceit3ikggulbb54cxf-3Canon Pixma iP1500: How to insert 5 springs on int - canon-pixma-ip1500-insert-5-springs-inte-pj1gq0ceit3ikggulbb54cxf-3-4.jpgmages/canon-pixma-ip1500-insert-5-springs-inte-pj1gq0ceit3ikggulbb54cxf-3-4.jpg
Posted on Feb 11, 2015
  • byteotech Feb 11, 2015
    I just lined up the main housing, put the 2 screws in the front (did not screw in the 3 side screws) ( tried it when the housing was off the springs would just fall down) just slide the springs in after it is screwed in the short side fits into the white plastic you will see grooves where it lines up on the white plastic piece, the long side of the spring hooks on to the back metal hook on the other side the coil rests in the middle of the prongs http://i945.photobucket.com/albums/ad294...
SOURCE: canon pixma ip1500
How do I change the "Waste Ink Absorber" on my Canon Pixma IP 1500? Where do I get the absorber part? Thanks.
Posted on Nov 29, 2008
  • 32 Answers
SOURCE: I have cannon pixma ip1500 printer sold in good
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
Posted on May 28, 2009
  • 84 Answers
SOURCE: waste ink tank full
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
I tell you what. Before you decide to reseting the waste ink counter, you should really clean up the ink absorber, or else you will find the ink watse absorber overflow...
Posted on Aug 26, 2009
komguy
  • 2306 Answers
SOURCE: I appear to need to replace the waste ink absorber
Canon built several models like yours that you can't get an ink absorber for. They are only exchanged during the warranty period where they send you a new printer. After warranty it is considered a throw away printer.
Posted on Nov 18, 2009
Testimonial: "Thanx for your message"
pineworks
  • 4041 Answers
SOURCE: Pixma IP1500 stops
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Posted on Feb 13, 2010
The waste ink absorber is fll. Can I get one and exchange it?
Ink Counter Reset - Canon IP1000/1500
1st Option
1 Unplug power cord
2 Press and hold power button
3 Plug in power cord and switch on power - still holding power
button
4 Still holding power button press resume button 8 times
5 Release power button
6 Press power button to turn on
2nd Option
1 Turn off printer and disconnect power cable
2 Press and hold power button, reconnect power cable and switch power on
3 The indicator (LED) should be GREEN
4 Press and release resume button, still holding power button, the indicator (LED) should be ORANGE
5 Press and release resume button again, still holding power button, the indicator (LED) should be GREEN
6 Release power button
Oct 12, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Can't get printer to resume printing after cleaning ink absorber pads
Canon PIXMA iP1500
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and hold the RESUME button again, the indicator
6. Release both buttons
Courtesy of Indoreset Yahoo Group
Jul 20, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I appear to need to replace the waste ink absorber on my Canon Pixma iP1500. Any help please.
Nov 18, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Waste ink tank full
Aug 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I have cannon pixma ip1500 printer sold in good working condition buyer wants refund saying the waste absorber is full, therefore dont workHELP
May 15, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
How to fix the waste ink absorver
You take it to the service and they clean the printer and reset the waste ink absorber. I did it twice.
Feb 02, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma ip1500
Jan 31, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
549 people viewed this question
old marine
old marine
