My 50'' RCA MODEL# M50WH74s has low volume when turned up all the way,I went into the menu and turned up all the master volumes and it still low when I'm watching tv.But if I play my video game the volume is fine.
    Genius:
  • 3,587 Answers
Hmmm...so the volume is low when you are running some other input? What do you have driving that tv, since the amp obviously works with game ports.
Posted on Mar 27, 2008
  • Patrick Michaels
    Patrick Michaels Mar 27, 2008
    on the other hand, video game sets usually have a stronger output signal than regular dvd or cable boxes, so you MAY have a bad amplifier..you a technically inclined person?
The volume on my phone has gotten low,how do i fix it to increase the volume
Hi there, this depends on the make / model. Usually ther are buttons, not very visible ones, on the side of the the handset for raisins, increaing or lowering / decreasing volum, have a looksee ... maybe they are present.
If not the adjustment maybe in the settings section of the menu. Look for phone settings / volume. Also ... check the profile settings, it may be on 'quiet'.
If none of this helps please add make and model of your phone and repost the query
Jun 08, 2016 | Cell Phones
My little sister's RCA TruFlat 27" TV won't turn on. I don't know it's model number. I have it connected to cable and it works, and I know the wall plug works. The little red light that I press to turn on...
She changed the Frequencies per second (in the Americas it has to be 60 hertz, In Europe, Asia, and elsewhere it has to be 50 hertz). Changing that will cause the tv to self destruct.
Oct 20, 2013 | Televison & Video
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
M
Mar 10, 2011 | Cell Phones
No sound
You might want to double check all of the audio settings within the menu to make sure is it not in the SAP mode (Second audio programming). Also make sure it's not selected to ext speakers.
Apr 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA MP3 TH1100A Charge Problem
Get the firmware upgrade first. If that fails, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails, the Mp3 player has a hardware issue and needs to be replaced - call RCA.
-Tha Mp3 Doctor
May 25, 2008 | RCA TH1101 MP3 Player
Back light went out
Apr 02, 2008 | RCA OPAL M4001 MP3 Player
Opal mp3 player 4018
If that fails, it is really broke - call RCA and see what they can do
Mar 30, 2008 | RCA OPAL M4001 MP3 Player
TROUBLESHOOTING VOLUME ON PROJECTION HDTV , RCA
did you go in to you menu and set you audio setting.
Feb 15, 2008 | RCA 32F531T 32" TV
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
