Question about Zebra TLP 2844-Z Thermal Label Printer
Prints only the first label, then stops
The printer only print one label (the first label) then stop printing no matter how nay labels you sent to the printer. When you try to feed the printer, it does not advance the label. until you restart the printer then you can feed but it will not continue printing the pending labels.
When you print the configuration labels, it prints only this and then stops:
5 MU V4.70.1A
1A070300484
Please, assist
thanx
Dan
  • 9 Answers
SOURCE: Printhead light comes on
if you are using software that using printer please the s600 printer driver to direct thermal mode to solve the problem.
Posted on Oct 31, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
Madbigwhoper
  • 13 Answers
SOURCE: HOW TO REPLACE LABELS
Look at this I think it will help.
Posted on Feb 05, 2009
  • 254 Answers
SOURCE: Label over run
Check the size of the label in your codes or driver.
The length must be correct or else you cannot use it correctly.
You must may be recallibrate the sensors
Posted on Sep 03, 2009
  • 32 Answers
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Posted on Oct 27, 2009
Print dosent stop
u have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Jun 25, 2013 | Zebra Eltron TLP 2844 Thermal Label...
After I sent a print job to the printer, it prints out the label required but it does not stop feeding the labels. Please advice how to resolve this.
hi,
- Turn off the printer.
- Remove the labels roll and then load it again.
- Press and hold the green[feed] button and switch on the printer.
- Release the button after it flashes red.
- The printer will run a self test.
- Turn it off and then on again.
- Now print.
good luck!
Sep 15, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
Labels unexpectedly stop printing half way through a job
Located winder further away from printer. Set winder to lowest possible speed setting. Thoroughly cleaned printer to remove any trace of label residue near print head and label cutter (sticky labels with pre-cut patterns are being used). No more problems reported. Will continue to monitor.
Jun 02, 2009 | IBM Infoprint 6700 R40 Printer
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Motor throtting
This error appears when the printer has worked for more than 1 hours continuous, and to protect the printer. Wait a few minutes for printer to cool and continue with your printing.
Jan 22, 2008 | Datamax I-4208 Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
187 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
