Question about GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque
Ice maker leaking water - GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque
  • GE Master
  • 8,220 Answers
That most likely is a bad water valve, they drip just like a faucet with age. A simple repair.
Posted on May 04, 2010
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
May 11, 2016 | Refrigerators
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Leak on the ice maker water supply
Good day,
The house water supply is connected to a dual water valve on the bottom rear of the machine. It splits there going to the ice maker and water in the door.
If the ice maker side is feeding water to the ice maker even though the ice maker is in the off position means the diaphragm in the valve is leaking and must be replaced. Very common problem.
Apr 11, 2010 | Refrigerators
Shelf kitchenaid Refrigerator's ice maker leaking water
Turn off the water line that goes to the refrigerator and see if still leaking if not the problem is with the solenoid valve ,which is an electric valve that opens only when the ice maker calls for water and is located at the back of the fridge in the bottom behind the cover(if your refrigerator has water and ice dispenser ,Its called dual valve). And if leaks when you turn on the water ,this part has to be replaced .But if leaks and overflow the ice maker only when it calls for water the problem is in the ice maker and to repair it will cost almost as a new one .
Aug 13, 2009 | Refrigerators
Ice maker is leaking water. Never has worked well takes for ever to spit out ice. Now ice is all over everything in freezer since leaking but will still make some ice. I have had for 2 years/.
Do you have a water softener? This puppy won't work right if you do. ice maker leaking water? Ok lets do the scenario. This fancy ice maker will fill the ice mold in stages according to resistance levels measured by the control inside the IM. I initially will judge resistance in the ice mold and then will call for water. It will again judge for full ice mold by checking resistance. The 3rd attempt will supposedly satisfy the requirements of the ice mold. If the water softener goes into reverse osmosis(that time or the month for water sofeners). Then electrolysis will occur in the ice maker and some different resistance readings from what is built in is read. Oops! overflow of ice maker and weird ice production. Solution. Remove ice maker from the loop. Water softening is good for the clothes but hell on the ice production.
Jun 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Apr 27, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque Logo
260 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
