Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Washer not draining
Periodically but more receintly, consistently, my series 100 washer will leave my clothes soping wet upon completing of the wash cycle. I have to take the clothes through 1-2 extra spin cyles to get them ready to get them into the dryer. The washer appears to go through the entire cycle correctly. What could be the problem?
I have a GE front load washer that wash going through the same problems of not spinning the water out of the clothes. After numerous trouble calls I finally convinced them that it was not consumer ignorance on how to operate a washing machine. They finally replaced the main conmputer board and the door lock gear and WA-LA I haven't had any problems since.. clothes are almost dry when cycle is completed...as they should be. Be persistent until they solve the problem, hopefully before the warranty is up!!
Posted on Jun 18, 2010
  • Bosch Master
  • 3,463 Answers
Probably the pump filter needs cleaning.
It should be located at the bottom front of washer behind drop down cover, turn anti-clockwise to remove and clean.
Posted on May 04, 2010
My machine doesn't rinse and drain properly, sometimes the clothes are sopping wet
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 12, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
My frigidaire crown series washer won't drain the water
water pump knackered or check brushes or if moved washer drain hose kinked
Feb 29, 2012 | Washing Machines
Won't drain completely.
Pump is not working on washer.
Aug 30, 2009 | Whirlpool Washing Machines
Washer leaves the clothes very wet. Drain has been
What you have is a broken drive coupling. When the washer goes into spin the pump does its thing but the tub does not because the drive coupling is broken.
SOME REPAIR PICTURES WITH
REPAIR MANUAL
Aug 28, 2009 | Whirlpool LXR6432JQ Top Load Washer
Does not drain completely
open the front panel of washer , and look at bottom on a side for a small fan , thats the DRAIN MOTOR PUMP , it could be clogged , remove , clean it , and try again , AJ
Jul 14, 2009 | Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Clothes too wet upon cycle completion...
Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
Jan 20, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
290 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
