Question about Farmall Tractor A-i,av,super A ,super Av Radiator
Farmall a tractor runs but makes a popping sound thru the intake pipe. The tractor hasn't been run for many years.
    Master:
  • 401 Answers
It is a valve not seating letting a little got back on the intake, Also another thought what octane are you running? This tractor was originally designed to run 92 octane with lead in it. If your running low octane this might be a little spark knock your hearing
Posted on Dec 31, 2014
  • Randy Bower Aug 20, 2015
    I agree it is a intake valve issue,it could be just sticky from setting,or improperly adjusted,or burnt or bad intake valve.
    Problem Solver:
  • 16 Answers
Possibly a timing issue. Check the timing first. Also check the compression to verify both are within spec
Posted on May 11, 2014
5 Suggested Answers
SOURCE: it is a 1947 farmall
Two possibilities come to mind:
- the water pump impeller may have so much oxidation on it, it's not pumping enough coolant
- the cooling circuit in the block has so much oxidation in it that it is restricting the coolant flow rate through the block
It's like my arteries, I'm the same age as your tractor, and believe it or not my father once owned that same tractor.
I don't remember, does it have a thermostat? . If it does, you could remove it -- that might help.
Posted on May 07, 2009
wilsodfarm
  • 986 Answers
SOURCE: 1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
I think you still have a fuel issue like your float level is to low,I hope this helps you
Posted on Sep 10, 2009
SOURCE: Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
Posted on Dec 13, 2009
  • 51 Answers
SOURCE: NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
Posted on Aug 01, 2010
How do I hook a 6 Volt Battery up on Farmall Cub Tractor
look for positve on battery a + sighn is what you are looking for on battery then find positive battery cable in tractor no witch it between pos cable neg cable hook neg to battery fist to battery then hook up positve cable ready to start
Sep 02, 2014 | Garden
What would cause the alternator to run hot on a 1949 farmall cub tractor
Sounds like your still running power thru the original regulator also. Disconnect the original system completely so that your running power directly from alternator's inboard regulator and to the battery. Nowhere else.
Aug 31, 2014 | Cars & Trucks
Blowing flames
Hello Carleton, Fire out of the exhaust port with no pipe is normal. You want to bring the piston to top dead center on the compression stroke. Both valves should be fully closed.
Mar 24, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My farmall a will only stay running with the choke fully on. It has no power when in use. Possibilities?
Sounds as if the primary fuel intake inside the carb sounds plugged with either old fuel or junk that got past the fuel filter into the carb. Will require disassembly and thorough cleaning of the carb. I have read of some success with a product called engine med, available on Amazon, that will clean out gummed up fuel systems- with good reviews. I do not have experience with this product.
May 08, 2011 | Farmall International Tractor 140 Radiator
May 30, 2009 | Farmall Cub Tractor Radiator
Tractor stalls after approx. 15-20 of run time (1957 farmall cub)
try the 12volt coil. and remember the positive verses ground . you might have to order one from whitenys.com search that web site , i hope i spelled it right ,dang it sucks being 50 years old and cant remember things. but any ways check that website out okay .
Nov 26, 2008 | Farmall Toys
Farmall Tractor A-i,av,super A ,super Av Radiator Logo
228 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
