Question about Graco 9445DOH Crib
Need new mesh fabric for repair
My 4 yr old granddaughter cut out the mesh end of the pack and play - yikes! Now her 7 week old brother will be able to crawl right out when he is old enough.
The mesh is navy blue. I am a good seamstress and am hoping to find navy blue or black mesh to make the repair.
How might I locate the material that I need? (Now stop laughing!!)
Thanks Diana
2 Suggested Answers
SOURCE: need instructions on folding and storing an 8 yr old pack n play
I have one that is about this old, so if it is the same one, the instructions for how to fold it should be printed on the very bottom of the play yard. If they are not, then try to pull the center part up halfway. Next, push up on each side where the arrows are and as you do this, it should start to collapse and you should be able to fold it completely by pulling the center all the way up.
Hope that helps!
Posted on Jan 16, 2011
I have a Fridgeadaire MTRF322 F/F - 7 yr old. The thermostat in the fridge clicks in when I turn to 7. I then turn down to 3 - 4 as per instructions. The fridge gets cold, even ices on the back but then...
While on holiday, leave it on 7. When you get back, get the thermostat changed, but only after checking the following:
Condenser grille clear and clean, all fans working ok, defrost freezer and recheck fridge, check door seals properly, try setting at 5 or 6 and see if the freezer is better able to hold temperature
Aug 07, 2012 | Refrigerators
I need a chain for a 21speed mountain bike it is an older mongoose MGX i dont know what kind or size chain i need can you plz help me out???
Look around for a 7-speed chain. Special tools are involved for 'cutting' it to size so why not just establish a relationship with your Local Bike Shop now?
http://www.parktool.com/blog/repair-help/categories/chain-repair-and-service
If it's really worn you'll probably also need to replace the cogs and possibly the chainrings. Old drive train parts don't mesh well with new ones.
Use the web to answer common questions.
http://sheldonbrown.com/chains.html
Sep 19, 2011 | Cycling
I couldn't find the Brother XL-3520, so I'll just ask here. I noticed that I have a single needle (already attached to machine) and a double needle attachment but I need a thicker needle for...
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
May 17, 2011 | Brother XL-3510 Mechanical Sewing Machine
Have a brother xl2230 has been working now the fabric went pull through what can I do ,the thread bunches on the end and the fabric just stays there
I need a little more detail, was it working ok and feeding the fabric through, then stopped moving? How is your top tension? Set at 3 or 4? No thread caught in the bobbin area? What is your stitch length? What kind of fabric, and what size needle? See, there a lot of things that I need to know in order to help you, Please give as much detail as you can when stating your problem, don't forget, we can't see what you are doing,
Apr 22, 2011 | Brother Sewing Machines
Need to change the batteries in a Stanley bar flex light. lost instructions. how do you change the batteries.
I know this thread is old, but I just had to change the battery pack in mine. I could not locate a 4 pin battery pack so here's what I did:
You'll need: 3 NiMH 1.2v AA solder tab batteries, Razor blade, #1 Phillips driver, Kapton tap (standard electrical tape will do), soldering gun/iron, spare 18awg wire
1. Use a razor blade to remove the black sticker from the bottom of the flashlight base, it covers the magnets
2. remove the three outer phillips screws (the inner ones hold the magnets in and can stay installed)
3. Pull off the bottom plate
4. Pull out the battery pack and disconnect it from the flashlight at the 4-pin queeze connector
5. Remove the outer wrap and end protectors from the old pack keeping the end protectors in tact
6. Assemble the 3 new batteries in the same configuration as the old pack using Kapton tape, connecting + to - at the same two spots (use the old pack as a reference)
7. Carefully desolder the 2 wire leads from the old battery pack
8. connect up the 2 power wires to the same two spots as the old pack and insert the temperature probe between two of the batteries as in the old pack
9. Put the end caps on the new pack and wrap the entire thing in Kapton tape to simulate the plastic wrapper you removed
10. Install pack in to base, secure bottom plate and re-adhere black sticker(if needed you can use non-foam double-sided tape or spray adhesive)
The old pack was rated at 1300mAh and I used three 2000mAh each for a total of 6000mAh so theoretically the light should run for about 6 times as long between charges.
Aug 28, 2010 | Garden
How to remove liner from evenflo carseat
As a whole, they don't really fit well going back on. If your desire is to clean this, I do it on a nice outside day with a scrub bucket to give a soapy wash, then rinse with the garden hose, drying in the sun. Nasty weather and you still need to clean, get it to the bathtub or shower. I just did granddaughter's potty accident in the shower, set near heat vent and it was dry over night.
If you do it the way I listed, you don't have to worry about the buckle system, which is a bear to get right.
I have taken and done infant rocker car seats/stroller combination and ended up repairing the fabric, it does not wash well, even tho it might say washable. My 2 yr old g.d. has the up sized seat and the 6 yr old the full booster, we use shower or garden hose them down. They mean with a sponge/rag and air dry. Just one more item in our disposible society that should not be!
Hope this helps, good luck.
Jul 13, 2008 | Evenflo Generations
Jennair dishwasher is locked. Can't get anything to work. No lights come on. 2 yr old granddaughter pressed buttons now I'm stuck.
one of the buttons may be a "lock" pad. there should be a picture of a lock next to pad. press and hold for 3 or 4 seconds and see if panel unlocks. otherwise disconnect power to D/W and reconnect after 2 minutes.
J
Jun 19, 2008 | Dishwashers
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Emerson tv trouble shooting closed captions
I handed the remote back to my visiting 4 yr old granddaughter and asked her if she could make the words go away.......she showed me the "language" button on the cable remote and told me she likes to see the words so she can "read" them. Ya'll need a new "expert"? she works cheap.....red suckers.
Mar 21, 2008 | Televison & Video
Graco 9445DOH Crib Logo
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
