Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite he3t front loading washer and the washer will not spin or drain and shows an f2 code. any suggestions
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore washer he3t F2
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite Washer
Try this first.
Washer won't drain or spin
Is the drain hose clogged, or the end of the drain hose
more than 96" (2.4
m) above the floor?
Is your voltage low?
Check electrical source or call electrician. Do not use an
extension cord.
Is the "SUD" routine active?
Cycle will complete once extra suds are removed.
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
199 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
