Question about NEC MultiSync LCD4010 40 in. Television
The NEC 4010 i have comes on backlight lights up no information shows on the screen then it shuts off.any idea whats going on here.
  • NEC Master
  • 8,457 Answers
Yes,Ur Main Tuner board is defective,it shorted not letting the incomming signal go through the Tuner board,that why u getting a blank baclklight on the LCD screen.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on May 04, 2010
  • nectvuser Feb 23, 2011
    Were you able to fix this problem? I changed the main tuner board, t-con, and power supply and had no luck. Any idea what could be the problem?
NEC LCD 4610 Screen black.
Possibly the replacement power supply may have failed.
Feb 02, 2014 | NEC Televison & Video
Nec 4010
replace leak or bulged capacitors at the power supply board.
Sep 20, 2012 | NEC MultiSync LCD4010 40 in. Television
Nec lcd2080uxi, monitor power light comes on green but no video is being displayed, screen stays blank , cannot get into the built in setup selections. nothing is being displayed on the screen
Power supply or backlight inverter problems, those are the two areas you need to check.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | NEC LCD2080UXi Monitor
Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
Back light keeps flickering and sometimes wont work
back light wont need to be replaced most likely, tighten the connections. yes the manufacturer can replace them you could too if u had the skill, money, and time,
Jun 13, 2008 | NEC MobilePro P300 Pocket PC
Video problem
shine alight on the screen to see if you see any Icons if you do change the inverter board if not may be the display.
Nov 11, 2007 | Computers & Internet
NEC MobilePro 780 Screen
A couple of things spring to mind. Have a good hard look at the screen when it goes dark. Is there still an image there but it is really dark? If so, consider that it may be a faulty backlight. It may also be a faulty ribbon cable joining the screen to the main unit, or it may be that the brightness down button is stuck and causing it to lower the brightness. The fact that you are pressing the brighness (up button I am guessing) and it comes back on, may indicate the bright down button is stuck or by pure chance you are pressurising the board in that area causing a bad contact to work, such as power to the backlight or pressure on the ribbon cable. I dont have one of these MobilePro's but I am just going on things I have seen with notebook PC repairs. Hope this helps.
May 25, 2007 | NEC MobilePro 780 Pocket PC
My monitor not stay on
Very common for this model that top backlight globe goes faulty. Can be also inverter PCB fault. If you have couple spare lights connect them to your inverter instead of panel lights and see if fault remains.
Mar 28, 2006 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Mar 20, 2006 | NEC PlasmaSync 61MP1 61 in. Television
NEC MultiSync LCD4010 40 in. Television Logo
449 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
