Question about Kitchen Ranges
I pushed the knob on to start a load. the water started for 2 seconds then stopped. the machine will not start at all now.
  • simhoff05 May 04, 2010
    i'm sorry...i'm talking about a top load washing machine (kenmore 400).
    i'm talking about a washing machine. top load kenmore 400.
  • 2,335 Answers
Please post the make and model of your appliance. The more information you provide, the more accurate and specific we can be with our solutions.
Posted on May 05, 2010
  • 229 Answers
It says a kitchen Range, but I think you are talking about a Dishwasher.
If the water starter for 2 seconds and stopped and when you press it again water does not start, the valve is not opening.
Check the circuit breaker, make sure you have power to the dishwasher.
If the power is ok then there is no humming/motor starting, it is because the water level has not been reach.
If you have hard water in your area the valve could be stuck. The solution would be to replace the value. If you have a model number the part can be searched for on the internet. If you are handy, you can replace it yourself. Else it is a $80 house call. Good Luck
Posted on May 04, 2010
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
How many times do you turn knob on timer to set
You have to push the knob in to set it for the program you want then push it in to start the machine . You can pull the knob out at any time to stop the machine .
Apr 29, 2014 | GE WBSR3140DW Top Load Washer
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Spin cycle doesn't cut in
turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point nick_bradford2003@yahoo.com i have alot of experence with appliances
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
