I'm having a problem ping outside IPaddresses can anyone tell me how to fix this problem
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details and the complete make and model number
Thanks for using FixYa.
Posted on May 12, 2010
  • james_robins May 12, 2010
    When I try and ping an IP adress it returns a time out request.
    We have IBM Lenovo desktop computers.
    I can ping my internal IPadress , no external IP address. ex google.com. Yahoo.com etc.
Ping ip address
I think there may be a connection problem from your side or in that ip address you pining.So better reset the modem or router then ping it.
To ping ip address you can use method in windows XP.
Goto start-run-command prompt-Ping ip address
For example: Ping 55.253.12.86
You can ping ip address or website using the site Whoisxy.com
May 21, 2013 | Computers & Internet
Having problem internal network to connect outside but the router itself can ping the outside domain or public domain/IP. The Internal Network cannot ping the domain or cannot connect to the internet what...
1.Check whether there is ping to router from lan computers.
2. If there is no ping then check the cable b/w lan computers 7 router.
3.Else if there is ping to router, then check ur router for any ip blocks, access lists etc..
4. Turn - off the local firewall, so there also a chance of it blocking access to internet
Sep 27, 2010 | Cisco 881 Fast Ethernet Security Router
How to reset TrippLite SMNPWEBCARD
I bought a used power outlet control unit(PDUMH30NET).I could not find any instructions how to reset to factory defaults to clear out any static IP address and go to DHCP, so I pulled out the card, saw a small pushbutton between the 2 round connectors. I think the following process did the reset but its IP wasn't showing up at the router so I tried a couple of combinations before I found the IP with a PING scan.
Take off the small plate holding the card in(2 screws)
With a toothpick reach between the round connectors and press and hold the small button for close to a minute. I also tried
pressing it and holding it while inserting the card. The card takes several minutes to restart so wait for the green Status light. If you can't see it's MAC and IP address at the router, paste this in a Command window and run it:
FOR /L %i IN (1,1,254) DO ping -n 1 192.168.0.%i ' FIND /i "Reply">>
c:\ipaddresses.txt
Look in the file for an IP that wasn't on your network before- that should be it.Put it in the browser and you should get the login. admin/admin got me in.
Sep 10, 2010 | Tripp Lite (SNMPWEBCARD) Remote Management...
My cisco 877 dsl router sometime disconected from internet itself and after 5 or 6 hours its return back what can be the problem
1. check the status to the router page by logging into the router to see if the router lost connectivity.
2. Pinging an outside address will tell you if you have lost connectivity with the ISP or not.
Ping test = Ping www.yahoo.com
this is within the router
Apr 19, 2010 | Cisco 877 ADSL Security Router
My 1999 r1 splutters a bit from set off to 4000 revs then clears to perfect running
99 yzf r1 hit in back tire fell over and eversince makes a pinging noise when i release the clutch but when i pull it in it stops,the pinging noise sounds like its comming from the front maybe "carb" anyways theres no horsepower so i changed my plugs and oil still no fix can anyone tell me whats wrong with it
Jun 05, 2009 | 1999 Yamaha YZF-R1
Packetloss
Hard to tell without knowing your setup. How many servers do you have and how are they connected (workgroup, domain)? Sounds like it could be a configuration somewhere.
Feb 07, 2009 | Microsoft Computers & Internet
Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
