Question about Toshiba Satellite A25-S207 Notebook
Upgrade Hi !! I want replace my hd. Capacity and brand matters (abt 100gb or more) and memory I've got 512 (2 slots busy), can I replace one 256 for 512 or better both for 1024?
  • 807 Answers
You can put 512Mb in each slot.
Look here for the details of your notebook.
http://www.fixya.com/support/p264641-toshiba_satellite_a25_s207_pc_notebook/manual-14808
Posted on Mar 26, 2008
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
How can I upgrade memory from 256MB?
Check any free memory slots available in the laptop and upgrade the same.
Revert back for assistance.
Jan 20, 2010 | IBM ThinkPad R32 2658 Notebook
Just need to know how to change the ram in my Sony Vaio PCG-v505ap
visit vaio manual in
ftp://ftp.vaio-link.com/pub/Manuals/Notebooks/
You can do this in two ways: opening your notebook and taking a look on the memory modules already installed (we will explain more about this later) or running a program like Everest (available on our download section). We ran Everest (going to Motherboard, Chipset, Memory Slots) on our notebook and found that it was using two 256 MB DDR-SDRAM PC2700 (“DDR333”) modules, for a total of 512 MB.
imageview.php?image=1680
click to enlarge
Figure 1: Checking your current memory configuration with Everest.
If your notebook has an empty memory slot, just go to the computer store and buy a new SO-DIMM module with the same technology (SDRAM or DDR-SDRAM) and speed of any capacity you want – of course you need to know the capacity limit of your notebook. You cannot install a 1 GB module in a notebook that only accepts modules up to 512 MB, for example. Our notebook – a Sony Vaio PCG-V505ECP – accepts modules up to 1 GB, for a total of 2 GB RAM, since it has two memory slots.
For example, if your notebook has one 256 MB module and an empty memory slot, if you buy and install another 256 MB module, it will have 512 MB RAM. If you buy and install a 512 MB module, your notebook will have 768 MB.
If your notebook already has two memory modules, you will need to remove one of the installed modules in order to install the new one. If the two modules have the same capacity, it doesn’t matter which one you will take away, but if they have different capacities, remove the one with smaller capacity. The new RAM capacity of your notebook will be of the capacity of the remaining module plus the capacity of the new module.
In our case, our notebook has two 256 MB modules. So we will remove one of these modules and install a new one on its place. We bought a 1 GB-module, so after installing it our notebook will have 1,280 MB RAM installed (memory math is tricky, since 1 GB equals to 1,024 MB not 1,000; so 1,024 MB + 256 MB = 1,280 MB).
else visit
http://www.hardwaresecrets.com/article/189/1
Jul 02, 2009 | Sony VAIO PCG-V505DXP Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
E machine T1150 wont start up
Make sure you have the memory installed correctly. Those beep codes identify it as bad memory. Try the old RAM.
Good luck with this.
Mar 19, 2009 | E-Machines T6420 PC Desktop
Memory upgrade
The memory should be DDR II Ram. To find how much ram you have simply click on Start then right click on "My Computer" and click properties. Chances are you have 512 ram. It will tell you in the lower right hand side along with your processer and windows version. Once you have found out how much ram you have, turn off your computer flip it upside down and pull out the battery. Then you should see a cover with one or two screws in it that measures about 3 inch by 4 inch. Remove the screws and take the cover off. This is where your memory goes. If there is 512 memory in your computer you will either have 1 512 memory stick or 2 256 sitcks. Remember that any time you upgrade memory it is best to take out the old memory and replace with either one stick of higher ram or two of equal ram. Never mis a 512 and a 256 or 512 and 1gig ect. Take the ram stick/sticks out and bring them down to the store with you just so as to get the correct memory. Also, remember when you replace the memory, if you are just upgrading to one 1gig stick to put it in the A DIMM slot. This is the primary ram slot.
Apr 29, 2008 | HP Pavilion dv6000z Notebook
Ram upgrade
In most cases if you put of not thesame capacity in any computer later will create further problems. it can damage the other memory or both and the worse is when also the motherboard will also damage.
That is why im telling you this. Please prevent inserting memory of two or three different capacity. You should not do that.
You should select etheir use all 256mb or all 512mb or all 1gb.
in the T4200 since max. is 1.5gb, either use 3-512mb if can carry the maximum if not , then use only 2-512mb.
in T3624 since max is 2GB. You can try 2-1gb if can carry the maximum if not, use only 1-1gb.
Note:
You can use or inserting at different capacity but is at your own risk. "
Ps. does no matter either you put smaller or bigger in first slot.
Mar 18, 2008 | E-Machines eMachines Desktop PC
Ram upgrades
Does'nt matter which goes where as long as they are all compatible with the motherboard.
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Toshiba Satellite A25-S207 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
