Question about JVC KD-S100 Car CD/ MP3 Player
The clip on the back of my faceplate somehow broke off and now it wont snap back into place. how would i go about getting a replacement part for my KD-S100?
  • kenw392
    kenw392 May 11, 2010
    try pacparts.com. they have a phone number listed there if you need more assistance.
4 Suggested Answers
bigTROY502
  • 129 Answers
SOURCE: i need to replace my faceplate only because someone stole it
www.pacparts.com
Posted on Aug 11, 2009
  • 14 Answers
SOURCE: Where can I find faceplate replacement for jvc kd dv 5100
Ebay is the best place to find faceplates, a faceplate will be anywhere from $15-45.
Posted on Nov 15, 2009
kenw392
  • 2226 Answers
SOURCE: can i get a replacement part for the kd-g320 all i
The only way you are going to find another chassis is in pawn shops or garage sales. You are better off buying a new radio.
Posted on May 20, 2011
My Pioneer DEH-P9800 BT faceplate won't close
The clip that locks the plate into place probably broke.
Mar 20, 2013 | Pioneer DEH-P9800BT - In-Dash CD/MP3/WMA...
Interior trim panel removal instruction
Normal 0 . Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
If you don't have power windows you will have to remove the manual window crank. It is held in place by a clip on the back side of the base. To remove the clip, you will need a small hook (kind of like a knitting needle). Put the hook in behind the base, and grab the clip and pull it off. To replace it, slide the clip back on the window crank, and snap it back on the door.
May 31, 2009 | 2003 Volkswagen Passat
How do I remove a 1995 buick park avenue drivers side door panel?
Normal 0 . First thing, disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
May 30, 2009 | 1995 Buick Park Avenue
How do I remove the front door panel to replace the mirror
Normal 0 Disconnect your negative battery cable. Locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Remove the interior door handles, then disconnect the wire clips to the switches. Your panel is held in place by snap in clips; use a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are pulled, pull the panel upward to remove it from the door.
Install in reverse.
May 25, 2009 | 1998 Buick LeSabre
Engine air filter cover doesnt want to snap back on
Remove the filter and either clean it with water and let it dry completely before installing. Or buy a new filter. Place it so that it fits firmly down at the botom. the try to clip on the cover snapping the hard clip down first. then the opposite side. then snap on the others. it may have bent a little. If it fits loose. try bending it into shape .
Feb 06, 2009 | 2004 Volvo S60
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Jensen MP5720 radio/faceplate connector is broken or missing spring
I was always afraid this might happen to me so I never removed the faceplate from the radio. This strategy worked fine for two years until two weeks ago. I didn't lock my car because of the freezing rain and somebody stole my faceplate and remote. Anyway I ordered a replacement radio from Amazon last week so I don't have rewire a new one. The replacement cost me $100. I don't really need the rest of the radio so make an offer, my email is cs1713@sbcglobal.net
Regards, Chas
Sep 18, 2008 | Jensen MP5720 CD Player
How to remove center console faceplate?
after looking around the edges for small screws gently start prying around the edges at the corners first. the best option is to have your new cover plate in hand and u will see exactly where the snap clips are at and then you can "Gently" pry at those spots with a flat screwdriver to pop it off with
Jul 19, 2008 | 2005 Chevrolet Equinox
JVC KD-S100 Car CD/ MP3 Player Logo
53 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
