Question about Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive
How to scan and rapair my maxtor ounetouch 4 Mini
My usb external hdd has fallen down.
Now it cannot be seen (mount) from my windows xp. Is there a software to scan and rapair bad ntfs sectors?
Thanks for your help
Cheers
    Guru:
  • 1,481 Answers
Sorry...my guess is ur HD is gone...
once it falls down and cannot be identified as a Hardware by the OS...most probably it's corrupt....
the HDD needs to be loaded / identified by the OS / mounted.... to be able to access it....scan will not work unless it's mounted by the OS....
take it to a tech shop a c if they can fix it...
Posted on May 04, 2010
When I plug my maxtor in, I can hear it "thinking"
use an external usb ide( or if your hdd is sata,then use a sata cable)then insert to a working computer then you can copy your files
Feb 19, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
Install driver of maxtor 160gb onetouch 4 mini
Hmmm What software do you need?
You should not need software to run the HDD. Just plug it in.
You can get the One Touch software from Seagate (who no own Maxtor) See
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
HTH
Dec 08, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
MAXTOR EXTERNAL HD IS NOT OPENING
Does it give you an error message ? Are you running Windows XP or Vista? If so post it here so the problem can be further narrowed down.
You might want to try a chkdsk.
In Windows XP and Vista both, a shortcut to get to the command console is holding the Windows Key and pressing R.
in the command console, type:
chkdsk X: /f /r
Where X is the drive letter of the drive giving you problems.
This will run a chkdsk on your external, restoring files and folders that cannot be accessed.
I also have a Maxtor External hard drive and have to do this quite often. It's pretty frustrating.
Apr 04, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Maxtor One Touch 4 is beeping when I connect it by usb
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
I have a Onetouch Mini 4, operating fine on two computers with Windows XP but couldn't get it working on Windows 7. I plugged it in and it would be recognized but a message would come up saying there were errors and to scan. Tried scanning and not scanning and couldn't get the drive to work. If I tried to open it would give me the "access denied". I couldn't get to a security tab from a folder as none of them were working.
It ended up that I wasn't listed as an owner nor had any permissions so I needed to be added to the device.
Here is what I did -
System, device manager, disk drives, right click on onetouch, properties, volumes, populate, the select on touch volume, properties, security, advanced, change permissions, add, typed in my user name - hit checked names (it fixed the format), then hit ok.
Then make sure you set the permissions for all the users.
Sep 08, 2008 | Computers & Internet
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive Logo
138 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
