Question about Zebra Stripe S600 Thermal Label Printer
Pausing between labels
We have a Zebra S600 printer. The printer is pausing for about 2 seconds between each label print. Any suggestions?
  • 1 more comment
  • cjesgo Apr 18, 2008
    I am having the same issue...my lables print one at a time slowly, not continous. I have tried all sorts of settings to no avail. Has anyone found a solution to this?
    Thanks
  • tsavage Apr 25, 2008
    I have been able to speed up the print feeding speed and printing speed within the print driver, but still have an issue of it pausing between labels.
  • Anonymous Mar 17, 2014
    printing at 10"/s, pauses after printing each label. Will adding memory help?
I have found that using the designer driver causes this problem. You may need to go back to the originma driver for that printer if this is the case for you.
Posted on Jun 05, 2008
    Champion:
  • Zebra Expert
  • 285 Answers
Try to reset the printer to factory defult, chek if the driver is the correct driver frome the printer, if not go to the zebra website and download.
Posted on May 08, 2008
Zebra S600 - Printer pauses after each printed numbered label, if I don't number them it works fine?
It sounds like your labelling software is re-sending the entire print job each time. Do some research with your software and see if you can change the defaults so that everything BUT the serial number is stored inside the printer, and only the new serial number is sent.
It's difficult to be more specific because every software package is different...
Feb 10, 2012 | Zebra Stripe S600 Thermal Label Printer
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
Oct 29, 2010 | Zebra Stripe S600 Thermal Label Printer
My Zebra s600 - the ink takeup reel is not working.. works a little when first powering on, but the ink roll then stops moving.. When I print a label, the label comes out, but the ink roll does not...
turn the printer off, press FEED, PAUSE and CANCEL at the same time, still pressing, turn the printer on, wait untill the ligths coming on, and then relese the bottuns, it gona print the sensor profile, then press the last button 4 times untill the 3 ligtns flases, it mins that the printer save the data, then turn off and on again.
Oct 13, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 Thermal Ribbon Ripping after printing
Hi chunnon,
What darkness setting are you using? If the darkness is at or near 30, you may be burning through the ribbon.
Try defaulting the printer and running a Pause test. Does the ribbon tear during the Pause test?
Sep 23, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Sep 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
S600 pause printing problem
go to the driver and on Media change the speed under the Darkness.
Apr 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
756 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
