Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Unhinged drum/basin inside washing machine
I am looking for answers regarding how to re-attach (?) the drum inside the washer. It's as if it has come off and now spins wildly during the agitation and spin cycles. Is there a way I can fix this without having to call a plumber?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If this is a basic top load, direct drive, it sounds as if the "Drive Block Nut" has come loose and the tub is no longer connected to the drive block OR (hopefully not) the Drive Tube itself has broken.
See the following for how to access the tub and drive block / nut. (You don't have to pull the pump, motor and transmission to check them)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=55880a5f31d31ac718ac2f52fc75ffd8
Also see the Whirlpool / Kenmore Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
NOTE:
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
If the drive tube is broken (or the tabs have broken off) use the above procedures to pull the drive tube and brake in order to replace it.
If this is a basic top load, direct drive machine, they are relatively easy to fix if you are comfortable with basic tools (socket set, pliers, screwdriver). Being somewhat of a clutz, I've even torn the complete transmission down on one of these without any problem.
Posted on May 04, 2010
The wash basin is hitting against the side if the machine
Check the inside for a broken suspension damper.
Typically you can tilt the machine back and look underneath.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bad sound when the washer goes into it's spin cycle
Your drum spider bracket broke. You will need to replace the complete drum assembly. The drum assembly will cost about $325 just for the part. If you can replace it on you own it will save you alot of money. To repalce the drum assembly you will need to completely disassemble the machine. If this is the route you want to go. I can walk you thru the process. Just let me know. Jeff
Jun 01, 2009 | Frigidaire ATF6000ES Front Load Washer
When washer spins it seems to be off kilter the drum bangs the sides
Check the vibration damper rods for firm mount, and also the springs at the bottom of the basin.
May 31, 2009 | Washing Machines
Maytag Neptune Front Load Washer has Loose Drum, Bangs, Walks
Check the concrete blocks for cracks or peace broken off the shock will not cause it to do it that bad also check for movement up and down on the inside tub like a lose bearing
Mar 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine spring snapped but how do i attach it to the drum
That's quite tricky one, try make sure that you bought the right one, otherwise find some one to help you holding one side wile you stretch, it is dificult even with lotss experience. good luck
Jan 12, 2009 | Kenmore Elite 45986 Front Load Washer
Rusting basin
If you still have your book, look in the warranty section. The baskets on most models are covered 5 or 10 years against rust. That covers the part but not labor.($130-$160) If the rest of the machine is in good condition, it would probably be worth it. If you don't have your book, look up your specific model on the Whirlpool website and you should be able to find the warranty info. If it is no longer covered, the repair cost would probably not be worth it.
Oct 08, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
349 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
