Question about HP Pavilion 6736 PC Desktop
Need to install a new hard drive on a HP Pavilion 6736..Is there a upper limit to the hard drive capacity ?..The original disk is only 20 GB..Thanks
    Guru:
  • 1,481 Answers
In most PCs the MB and cables inside will have provision to add
2 HDDs
2 Drives (CD or DVD)
1 floppy drive(now it's obsolete)
in a IDE system the data cables inside will be aprox 3 inch wide and the MB will have 2 IDE slots to fix the cables....
in a SATA system the data cables inside will be aprox 1 inch wide and the MB will have 4 SATA slots to fix the cables....from 2 HDD and 2 Disk Drives....
you should know how to install a new HD and make it primary or slave depending on which HD has your OS...
google and find more details on that...
Posted on May 04, 2010
I have HP Pavilion dv6500 laptop with 120 gb hard drive. Are there problem issues upgrading to a 500gb or larger hard drive?
No there is no problem in upgrading the hard drive.
You can upgrade it as much as your system supports it.First check your system capacity of expansion of the hard drive's space.You must know the maximum capacity of the hard disk on your system .
Thanks.
Have a great day.
Sep 17, 2010 | Computers & Internet
Can I install a hard drive in an HP Pavilion 6736 which has a capacity greater than 20GB ? If so, is there an upper limit to the capacity..can I install a 120 GB drive?
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
May 04, 2010 | HP Pavilion 6736 PC Desktop
I have a hp pavilion dv 1659 us (dv 1000) the sata drive goes bad
It will recognize the new drive if you were able to "migrate" your data from the old drive. If not, you can clean install by booting from an optical drive (changing your boot order at start-up) and using a new OS disk or your recovery disks. You might be able to perform a remote partition & format and install from one drive to the other with USB external enclosures for each drive and another computer (depending on the 100G drive's condition). I hope this helps.
Feb 23, 2010 | HP Pavilion dv1000 Notebook
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
SCSI Disk capacity Limitation in HP-UX 10.0
your hard is only 2 gb?so its means that disk full?when you are installing windows xp the minimum capacty of the hardrive should be 3 gb try to look another hardrive!!just try
Jul 14, 2009 | Computers & Internet
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
I have installed s new hard drive maxtor 80 GB, the original one
First please check the Master/Slave connector at the connector side of Hard disk and install the jumper to Master or cable slect and if problem persist then you should have to update the Bios
Mar 28, 2009 | Computers & Internet
Hp pavillion9000 notebook hard disk broken
yes, just insure that you have the correct hard drive.... ata or sata.
Jan 26, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion 6736  PC Desktop Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
