Question about Karcher 2500 PSI Pressure Washer
Pressure washer will not put out any pressure
I have a karcher model hd 2500 dk kohler command pro 6 power washer. it started acting up last year. Now I cant get any pressure, the koler engine works great. I was not given any manuals on pump, just a book on 6-0 hp kohler engine that works great!!!!! please give me some help thanks, ken bailey at baileyken@live.com
  • 3,740 Answers
Hi Ken and welcome to FixYa. I am Kelly.
These pumps are notorious for seasonal problems.
Tip the unit to the point you can pour engine oil into the water inlet connection. What your attempting to do is free up the ball seats in the pump. They get corroded when they sit and lock in place. Adding the oil or a vast amount of WD 40 to the water inlet often does the trick for loosening up the seat balls and springs.
After you add the oil (3 - 4 ounces) or WD 40 to the water inlet line just slowly pull the engine through with the ignition switch off. As the water inlet cavitates add more oil.
Let it sit over night and then take a block of wood and a hammer and tap on the power head. Don't over do it and do it in such a manner your not going to shear off any bolts or break anything. But... be serious with the hammer and block of wood.
Then connect inlet water hose, the pressure hose and test the unit. You may want to purge the oil lubricant into a bucket before you start the engine.
Give it a try and see what happens.
Thanks for using FixYa,
Kelly
Take some engine oil and
Posted on May 04, 2010
Cannot start power washer
You will have to pull the cord 5-6 times for the fuel pump to fill up the carburetor. The carburetor doesn't have any fuel. Over the winter the carburetor dried up.
Mar 31, 2012 | Karcher 2500 PSI Pressure Washer
I have a Honda 2000 pwr. No pressure
check the o-ring in the pressure relief valve.
Sep 10, 2009 | Karcher 2500 PSI Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Jun 03, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
My Karcher HD 1050 DE has lost pressure, ive had new valves put on it but still has no go in it
could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
Oct 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
389 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
