Flex Grid I m not able for finding flex grid control, so plz tell how can access it. How can i operation on flex grid,like click on cell,add ,delete or update. i want to open any pop up on cell click.
    Problem Solver:
  • 7 Answers
The most common multidimensional array, the two dimensional array table, is best presented to your users in row and column format. The grid control offers a convenient way for you to display table data to your users. The users can navigate the table's values using scrollbars. Therefore, the grid control does not have to be as large as the table, because the grid control automatically displays scrollbars.
To add the flex grid control to your toolbox, select project and components. Add the flex grid control:
Flex Grid - lesson97-1.jpg Once it is added, you will see the yellow flex grid control in your toolbox:
When you place the grid control on your form, you will have to resize it before the control takes on a tabular appearance. As you expand the size of the control, it does not look to much like a table. The problem is that the table's default number of rows and columns are two. To fix this problem, you must configure the rows and columns in the properties window:
lesson97-3.jpg lesson97-4.jpg lesson97-5.jpg The grid control supports fixed rows and columns. These refer to rows and columns in a grid control that do not scroll when the user clicks the scrollbars. The fixed rows and columns provides labels that describe the data. The fixed rows and columns are often called row and column headers.
lesson97-6.jpg When working with the grid control, much code is needed to provide the grid with functionality. Call statements are used to break the code required by the grid control into smaller, more manageable procedures. This is referred to as modular programming (which refers to the practice of placing code with a single purpose in a general subroutine procedure and then calling the code from a second procedure.)
Here is the code for the form load procedure (this example is based on the computer disk example used in the last lesson)
Private Sub Form_Load()
Call SizeCells
Call CenterCells
grdGrid.Row = 0
grdGrid.Col = 1
grdGrid.Text = "Single Sided; Low Density "
grdGrid.Col = 2
grdGrid.Text = "Double Sided; Low Density"
grdGrid.Col = 3
grdGrid.Text = "Singled Sided; High Density"
grdGrid.Col = 4
grdGrid.Text = "Double Sided; High Density"
grdGrid.Row = 1
grdGrid.Col = 0
grdGrid.Text = "3 1/2 inch"
grdGrid.Col = 1
grdGrid.Text = "$2.30"
grdGrid.Col = 2
grdGrid.Text = "$2.75"
grdGrid.Col = 3
grdGrid.Text = "$3.20"
grdGrid.Col = 4
grdGrid.Text = "$3.50"
grdGrid.Row = 2
grdGrid.Col = 0
grdGrid.Text = "5 1/4 inch"
grdGrid.Col = 1
grdGrid.Text = "$1.75"
grdGrid.Col = 2
grdGrid.Text = "$2.10"
grdGrid.Col = 3
grdGrid.Text = "$2.60"
grdGrid.Col = 4
grdGrid.Text = "$2.95"
End Sub
Notice how the form load procedure is used to populate the cells in the grid control. To control cell size and cell alignment, two smaller procedures are created and each procedure is called by the form load procedure.
Private Sub SizeCells()
Dim intColumn As Integer
grdGrid.ColWidth(0) = 1100
For intColumn = 1 To 4
grdGrid.ColWidth(intColumn) = 2200
Next intColumn
End Sub
Private Sub CenterCells()
grdGrid.ColAlignment(intColumn) = flexAlignCenterCenter
Next intColumn
End Sub
Notice that the size and alignment procedures are only applied to columns 1 through 4. Column 0, which is a fixed column reserved for labels, is not formatted using either of the above two procedures.
Here is the final result:
Posted on Jun 17, 2008
How come on my 2005 pontiac aztek if i take out the rear defroster fuse (#21) the light still lights up on my dash and the relay still clicks?? Help why did this rear defroster stop working?!?
I found this. Your heated mirror also works off that relay. You can do ohms test on the grid, if the grid is open, no continuity. The auto store should sell a product to paint over the open spot to restore continuity, if you can find the open spot.
Not trying to cause trouble, just killing time. Have a good day.
Oct 24, 2016 | Pontiac Cars & Trucks
Rear defroster doesnt work already reset breaker and check fuses but one fuse in manual not on panel
i think this is a grid type(wires) rear defroster as opposed to a fan style.then when you push the button to turn on the rear defroster you should hear a click this tells you the system is working from the fuse to the rear window.what you have to do is check the rear window grid(wires) with a test light and you will probably find some of the grids not working which indicates a break in the grid line and needs repair.you start with a test light at one end and you should see it light up brightly at one end of the grid and as you move along the grid wire to the other side of the window you should see the light gradually get dimmer,when you hit a spot were the light stops working you just have to norrow down the area of the break and mark it with a marker below the grid,when you have done the complete window you will know the areas that need repair.you can buy a defroster grid repair kit and repair it.follow the directions.before checking the grid wires check the area where the car wires connect to the window at both sides of the window.sometimes there is a problem in this area.
Nov 08, 2011 | 1991 Toyota Camry
White screen only with trying to open it..but there is a sound when your pressing the keypads.
Hi,when a cell phone has a white screen display, it's occurs when the screen of the cell phone damaged..
Symptoms are that the cell phone screen will be white and you will able to recieve incoming calls, do some operations on your phone, but you will unable to view anything your doing on your cell phone.
You will need to replace the screen of the cell phone...
Also there are two models of 6600..
The 6600 slide and
the 6600 fold.
If it's the slide of the 6600 cell phone, that means you will need to replace the flex of the cell phone..
There is a common fault for all Nokia slide cell phones.There is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
You can use the below links for disassembling cell phone..
http://www.formymobile.co.uk/6600slidedisassembly.php
and
http://www.formymobile.co.uk/6600folddisassembly.php
Hope it helps.
Thanks for using fixya...
May 30, 2011 | Nokia 6600
My samsung s8300 mobile touch screen is not working, numeric keypad is working & on screen pannel only end button is working.
i bought this and solved the problem. NIKOS GREECE...
http://cgi.ebay.com/Samsung-S8300-Repair-Part-Ribbon-Flex-Cable-Tools-/380284533936?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D3%26po%3DLVI%26ps%3D63%26clkid%3D738272505495324217
Jan 16, 2011 | Samsung S8300 Ultra Touch platinium-red...
I have nokia n95 and when i power it on my lcd display onlye white and nothing else can you plz tell me how can i fix that prob
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Jul 30, 2010 | Cell Phones
The user's manual for my nokia 2600 classic says "To change the menu view, select Menu > Options > Main menu view > List or Grid." But when I do that, all I see is "Grid". There is no "List". ...
well when you see grid.. select it. after selecting grid again go for select Menu > Options > Main menu view > .... you must find the list option and if you don't then get it checked from the service center
Jul 31, 2009 | Nokia 2600
HIGHLIGHT THE CURRENT ROW
Hi Rakesh,
in MS Access 2003/2007, the first record is always highlighted in table as well form's text controls when they connected to a database. In a query cursor is always at last record.
In flex-grid control you can set its properties to get cursor on a particular records.
I think your problem is solved.
Please contact if not.
Zulfikar Ali
Mar 07, 2009 | Microsoft Access 2003 for PC
E 250 display
this kind of problems occurs when the flex cable is cut
flex cable is like a electronic part that connect the lcd to the keypad of ur CP.
plz tell me to help u further if this is not helping
plz rate this Post.
Aug 30, 2008 | Samsung SGH-D900 Cellular Phone
Camera not working.....
Hey guys, camera issues are one of 2 main things;
1)Firmware error - easy fix - just need to flash to latest firmware - may have been caused by bad program installation or file corruption
2)Camera malfunction - need to repace camera - probably water damage or moisture corrupted the flex cable or connector
http://horizonwirelessonline.com
Jan 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Flex connector
remove back cover and battery
you can remove ur front panel by using ur nail it self
u can find white keymat that willbe fixed with flexi , remove it
then remove lcd carefully
unscrew the the four screws in the back panel
then seperate D cover from front panel you can find flex conn
give some little care while removing flexi cable for its position .
plz follow the reci for assembly
Nov 04, 2007 | Nokia 6288 Cellular Phone
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
