Question about GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER OVEN DOES NOT COOK
Everything appears to be normal with this oven except it does not cook. When you start it the magnetron starts after the two second delay but only runs for about 1 second then it stops humming and the oven continues to run its time cycle without the magnetron.
Any Ideas?
  • Anonymous Mar 27, 2008
    hey i have this exact same problem..the model was made in 2002.. so im wondering if this is a defect since ours when out at the same time.. i checked for a recall and havent found one..please post anything you find out.. thanks
  • Anonymous Mar 30, 2008
    GE spacemaker microwave does not cook. Clock works, it will start cooking for about 1 second and then quit. Help!
I have a JVM1430 microwave, it has a 9 yr warrantee on the magetron, I called customer relations 800 386 1215 and they sent a new magnetron at no charge. Now it all works
Posted on Mar 31, 2008
  • GE Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, which we repair these nationwide by mail for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
JMy microwave come on, everything works but the food does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM 1631: Starts working and stops 3 sec later??
your magnetron is leaking RF do not use until you replace the magnetron, it is interfering with the pc board
Feb 05, 2010 | GE JVM1631 Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our oven would not heat,everything appeared normal lights worked fan worked timer worked tried again on cook 3 closed door and lights went out and we have nothing,I have 120 volts at plug.
Check the voltage at the primary winding of the highvoltage transformer. If it is 120 volt.then controll board part is. Now check the magnetron and related components. If the fuse and the diode are ok replace the magnetron
Jul 14, 2009 | GE Spacemaker JVM1740 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave power interruption
the unit may be detecting a mal-functioning magnetron.
Jun 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
149 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
