Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Convergence problem green convergence problem. I've ordered STk392-100 Which other parts may have to be checked/replaced? Thanks
    President:
  • 3,130 Answers
The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! Go to http://www.tvrepairkits.com/xcart/home.php?partner=larry
The kit comes with original Sanyo STK IC'S , not those cheap aftermarket or china made IC'S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
techman also go to.
http://www.fixya.com/support/r3342653-convergence_fix
Posted on May 04, 2010
  • Larry  Dillon
    Larry Dillon May 07, 2010
    if you order the kit you will not have to worry about that and you will get the original IC's not the cheep ones you can get online for less than 20bucks or so!!
    techman
My samsung pcl6215r is having problems with the green screen. The red and blue colors are fine but the green wont line up with them and its making it out of focus badly. It doesn't appear to be dim or...
brent hardin,
Your description of the problem sounds like a convergence issue. You more than likely have lost the convergence ICs. They will need to be replaced and the convergence will have to be set. The green beam should not move. It is the standard which the red and green are moved to overlap. Since you have bow at the top and bottom I would replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to replace the parts and where to get the replacement parts.
Thanks for using FixYa and for the great rating. Great ratings will keep the experts helping to solve problems. Thank you.
hardrocko
Nov 17, 2010 | Samsung PCL6215R 62" Rear Projection...
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
My convergence problem is the green convergence missing in menu
the only info you need is to replace the middle chemical fuse next to the flyback, I believe it`s marked "231" on most sets and then the critical parts is to re-solder ALL of the pins on the flyback transformer, 9,10,11 are usually cracked big time but you need to solder all of them, I`ve done this 50 times and never had a call back, gl, video-tek
May 29, 2009 | RCA HD52W59 HDTV Projection Television
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com.
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Green convergence not synced
I thing your problem is in convergence output it require Technicain job I can give part No. to order from Samsung but you still need to adjust convergence after you replace that part the adjustment require remote control and service manual and patient for instruction how to do convergence I can post it to you OK
now part No. is BP94-01259G or L
Nov 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
You can try unplugging and pluging back in, or checking to see if the ant. cable is tight
Feb 19, 2008 | Sony KP-51WS500 51" Rear Projection...
Picture issues, not sure what the problem is, photos posted
It looks to me like the green is sagging down at the top, and this means that one of your convergence IC's has stopped working. Instead of replacing the whole module, locate the convergence IC (Samsung typically uses the STK392-040 IC's) that handles Green Vertical (GV) and replace it. Sometimes there is a fuse next to the IC that looks like a small resistor that opens up too. If you do not have experience changing convergence than have a qualified tech handle it for you.
Jul 03, 2007 | Samsung HCM4215W 42" Rear Projection...
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
