Question about Nikon D50 Digital Camera with 18-55mm Lens
CHR message - Nikon D50 Digital Camera with 18-55mm Lens
  • 10,594 Answers
CHR error shows some problem with memory card in camera. Turn Off camera, take out memory card, reinsert memory card and Turn On camera.
Usually this error comes due to bad connection between camera and memory card contacts. Make sure battery contacts are cleaned.
Hope this info will help you.
Thanks.
Posted on May 04, 2010
Excel Tool VBA Password Recovery
Are you looking to unlock a protected sheet or actually recover the password? I can help you with the former.
Note this will only work to unlock a worksheet. It will not recover the VBA editor password (however this is possible by very hard to explain.)
1) Open the excel sheet you want to unlock,
2) Open VBA editor, (Alt+F11 while in excel)
3) add a module (insert > module)
4) and paste in this code into the main window (big window on the right)
Sub PasswordBreaker()
Dim i As Integer, j As Integer, k As Integer
Dim l As Integer, m As Integer, n As Integer
Dim i1 As Integer, i2 As Integer, i3 As Integer
Dim i4 As Integer, i5 As Integer, i6 As Integer
On Error Resume Next
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If ActiveSheet.ProtectContents = False Then
MsgBox "One usable password is " & Chr(i) & Chr(j) & _
Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
ActiveWorkbook.Sheets(1).Select
Range("a1").FormulaR1C1 = Chr(i) & Chr(j) & _
Exit Sub
End If
Next: Next: Next: Next: Next: Next
End Sub
5) Then either:
5a) go back to the excel window, click Developer > Macros > select PasswordBreaker
6) Or just hit the play icon (green triangle) in the top of the VBA editor
This will unlock the sheet, and give you a password which will unlock it in the future.
Note: Due to the encryption method used in excel, there are many possible passwords which will unlock the sheet. This will give you "a" password which will work but it will not be the one that you originally set up. Both the original and this one will still work.
Jan 20, 2013 | Excel-Tool Excel Tool VBA Password...
Error message Chr
Having received no response in over a month, I assume this is no longer a problem.
May 15, 2010 | Nikon D90 Digital Camera with 18-105mm...
I want to add 9 inch x 4 inch paper size on printer lq-300+
use following command
For 4" Height
Chr(27) + Chr(67) + Chr(0) + Chr(4)
For 6" Height
Chr(27) + Chr(67) + Chr(0) + Chr(6)
For 12" Height
Chr(27) + Chr(67) + Chr(0) + Chr(12)
Feb 22, 2010 | Epson LQ 300+ Matrix Printer
D300 cards not accepted chr message
try the last card you had in it before this problem occurred sometime the processor in the camera doesn't realize the disk is gone sort of like your computer once it starts reading a disk and you remove it half way threw the load. Well usually before yu can go any further on the computer you must put the **** back in and close the program out. This issue is usually case on cameras when the disk is removed before the camera is turned off.
Oct 08, 2009 | Nikon D300 Body Only Digital Camera
Getting (CHR)error message on my D80
Your SD card may be "locked." Check the SD cards slider lock and make sure it's set to allow you to write to the card.
Apr 14, 2009 | Nikon D80 Digital Camera with 18-135mm...
I don't see anything on the printer zebra 2844
Your must program in ELP2 printer language. You can download the [rogrammers maunual at www.zebra.com You can also call Andrew @908-725-1699
Mar 23, 2009 | Zebra LP 2844 Thermal Printer
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
How to set page length in computer for dot matrix printer model wep 800DX
to set up page length in inches
?? chr(27)+chr(67)+chr(0)+chr(12) - for 12" page length
to set up page length by lines
?? chr(27)+chr(67)+chr(50) - for 50 lines / page
Jul 20, 2008 | Epson LQ-2180 Matrix Printer
Nikon D50 Digital Camera with 18-55mm Lens Logo
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
