Question about Maytag PYE2300AY Electric Dryer
I have a pye2300ayw maytag dryer i was drying clothes and it just shutoff and will not work
It is most likely one of the thermal fuses. They can be checked out with an meter if the fuse is blown there will be no continuity across the fuse. This is what went on my dryer, the only bad thing is that the replacements don't seem to last as long as the original did. Make sure you clean out the trap really well you might have to take the from panel off it's only 2 screws.
Posted on Jun 08, 2010
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
MY MAYTAG DRYER PYE2300AYW TAKES 2 CYCLES TO DRY THE CLOTHES
I would imagine your vent duct needs cleaning. We recently had the same problem and a duct cleaning kit from Lowes (about $40) took us from what felt like 'reasonable' airflow outside to "oh-my-gosh, what a difference!!", and left an astonishing pile of nasty, damp lint on the ground out there...
There's a good chance the same treatment would do the same for you. Hope it helps!
Nov 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
I have a maytag model # pye2300ayw while in the middle of drying a load a clothes it just quit i turned it back on now the timer is the only thing clicking nothing else is happening
Check your breaker, then the wiring in the back. It sounds like it could be your thermal overload switch is bad. Does the drum turn on even though it may not have heat? This will help me analyze it.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Sep 17, 2007 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
186 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
