Question about RCA P60921 60" Rear Projection Television
Tv wont come on
Hello my tv wont come on at all now it is the rca p60921 i checked the fuse and it was fine i even had the power supply replaced still nothing it all started after a power outage and has not been on since and advice or help woul be greatly appreciated
  • 2 more comments
  • dalasone Mar 26, 2008
    yes its ptk195mt
  • flybutta Jun 08, 2008
    tv will not power on by front panel poer button or remote control. when front panel power button is pushed, there is a clicking noise at the rear of the tv at the point of which the power cord enters the tv. could hear the high pitched airy sound tv's have but the picture did nothing, not even a flash. now there is no click or any activity at all when the power button is pushed. we did unplug it for about an hour or so and upon plugging it back in, this is when we noticed the cloicking noise had stopped
  • Kevin Harris
    Kevin Harris Sep 12, 2008
    board has hole by flyback transformer, What board part ## do I need .Please help
    RCA P60921 60 in. Rear Projection, Chassis no PTK195MT
  • rgcnavy Oct 16, 2008
    I have the same problem with my RCA rear projection TV P60921 Chassis PTK195MT. I just recently replaced the flywheel on it and it worked for about 3 months and now it won't turn on at all. It does not turn on with the remote or by pressing the on button. I do not hear the same clicking noise it was making before when I needed to repair the flyback. It cost me $400 dollars to get that replaced and don't really want to spend any more money on it even though I love the TV itself. The Repair guy did give me a 6 month warranty on his work ...wish me luck.
    President:
  • 4,402 Answers
Do you have a chassis number? example PTK169PGB
CTC169PGB
Posted on Mar 26, 2008
32 inch rca getting power, but wont turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_29_2012_3_02_02_pm.jpg
left one is good and right one is bad.
Arrows point to bad ones
May 28, 2012 | RCA 32la30rq 32 Tv Black 720p Lcd - - RCA
Hello :i have a bad projection tv Symptom :power
sounds like my 32", its going to be one of three things,
Convergence board,
if it is this you will need to order one online and install it yourself, lots of guides online to help you with this process,
High voltage power supply,
again this can be purchased online and directions are available, if it is the high voltage supply, the tv will act like it wants to come one and maybe click a couple of times
Low voltage supply,
the tv will do nothing, now if the tv does nothing, the low voltage supply isn't the only possibility, but the most likely, check fuses on this one as they are easy
Jun 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA LCD TV 26 screen turns white, no sound no nothing
You have a blown fuse in the power supply. It does not look like a fuse.
It is near the top of the board and is labeled as 1.6 amp. It supplies 12
volts to the main board (via q422). A 2 amp fuse should be a fine
replacement.
Sep 04, 2009 | RCA L26WD26D 26 in. LCD TV
RCA P60921 Rear Projection TV
converge power supply small pcb about 3 inch by 7 inch with stk-730-xxx chip on it ..replace the chip
Oct 29, 2008 | RCA P60921 60" Rear Projection Television
Rca no picture no sound
There is no sound on my rca 60 tv. what can I do. The movel number is P60921.
Jul 30, 2008 | Televison & Video
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
RCA 52 rear projector tv makes chirpping noise wont turn on
You have a bad high voltage transformer. It is the white square device about 3inch square with large red wire coming out. Must be replaced with RCA original NO GENERIC. Also the horizontal output transistor must be checked to see if it is good. Recommend honest qualified tv repairman
Dec 30, 2007 | RCA P60921 60" Rear Projection Television
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
No power on RCA p60921
Replace the Power Supply switching transistor, If a CTC195 chassis it is the Q14101. Cost about $8.00 for part if you can do it.
Aug 04, 2007 | RCA P60921 60" Rear Projection Television
No picture
need chassis # ctc something look for it on the back cover
Jun 19, 2007 | RCA P60921 60" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
544 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
