Question about Philips Pocket Memo 381 Handheld Cassette Voice Recorder
Hi, When i try and record onto the machine it does not run, it sticks, tried new batteries but no difference, machine is about 2 years old, David.
  • 61 Answers
If ther is no drive, even in fast forward or reverse, the the belt may have come off the motor pulley. Otherwise you may have a hair wrapped around the tiny drive cogs under the turntable.
Posted on May 11, 2010
Sandisk ultra backup 8 GB recording & retreiving advice
The files will be replace if you use the same exact file name, but it will ask you first. You can "explore" - right click - from "my computer" - right click - and find the drive that has your flashdrive.. double click on that drive and the contents of your flashdrive will show up.. You will NOT receive a notice, but every time you add a file , it should show how much space is remaining...
Jul 18, 2017 | SanDisk 8GB Ultra Backup USB 2.0 Flash...
Repeated use
in the settings for back ups you can select files and folders to back up
the back up timing can be set from immediate to hourly , daily weekly even momthly
some back up systems copy and others copy and replace so ask around what your back up is going to be
My back up does everything every week and backs up onto a 1tb external hard drive
you should get an alert that reads something like-- unable to do back up because of insufficient space
or the same message if you try to download something onto a usb stick that is not big enough for the down load
Nov 14, 2017 | SanDisk 8GB Ultra Backup USB 2.0 Flash...
GoPro HD 960. The camera locks up after recording 5 to 7 minutes of video. Am able to record numerous short length recordings but if I let it run the longest I've gotten is 7:38m. Tested in the case, out...
Hi I found this:- Record up to 2.5 hours on a single charge and up to 9 hours total on a 32GB SD card (not included). Can you try another card, is the card correctly formatted is it a duff card.
Look up the user guide and that should help.
David
Dec 26, 2017 | GoPro HD Hero 960 Video Camera
Whirlpool 2298 automatic top loader machine is 30 years old. just after the suds return and up to three times through the wash cycle the pump switches on and for about 10 seconds empties water through...
Hi David,
sorry I can't solve your problem, but I wish to thnak you for your post. I have the same problem and pulled the timer out to give a clean with no luck. I did find evidence of a short circuit on one of the elements so something did happen. I have bee trying to locate a new/used timer - but no luck.. You would think that Whirlpool when making such excellent products would provide the service these long lasting devices deserve.
Neil
Sep 17, 2010 | Whirlpool Washing Machines
I can't figure out how to record message for answering machine
There should be a greeting or greet labeled button on the base.Hold it down and it will prompt you.If there isn't one,without turning on the phone hit the funtion button.There should be a directional button to cycle you through the options.It should be on the base though.We just got rid of our Uniden though because the batteries died and there are so many new ones that come out year to year,they don't even put out the battery anymore.It is less than 2 years old too.:( Good luck!
Jul 14, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Cannot get DVD recorder DVD 3470H to download from hard drive to a disc. The machine is about a year old and I'm using recordable DVD-R When I try to record onto the disc I get a screen which says the...
Hi Guys,
Thanks for the response.
I've solved the problem.
I was trying to download a programme that was too big from the hard drive to the disc.Once I inserted a divide in the progeamme everything worked Ok,
Cheers,
Dec 16, 2008 | Televison & Video
Logitech Freedom wireless joystick
i have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
Jul 27, 2008 | Sony Logitech Freedom (vs9632830403)...
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Dec 11, 2007 | Lite On LVW-5045 DVD Recorder
Philips Pocket Memo 381 Handheld Cassette Voice Recorder Logo
81 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
