Question about GE WBSR3140DW Top Load Washer
Will not empyt tank after agitation. will not go to spin cycle. timer buzzes loud even when pushed in to turn off. timer also spins with less resistance than normal. free floats if you will.
  • GE Master
  • 8,220 Answers
I have fished a shoe string out of the electric pump like this one has. Very easy fix. A little bit messy but easy to repair. No parts needed. Simply stuck a thin blade between the top and front and release the front panel to get to that clogged pump. will not empyt tank after agitation. will not go - 5070e4e.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 04, 2010
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Will not spin
Sound to me like a simple drive coupler replacement is needed. Go to youtube and look for 285753 replacement
May 15, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
It fills and agitates. Fills up then stops, makes a buzzing noise and will not drain or spin. What could be wrong?
in order to accurately diagnose this i will need the model number, but it could be that your lid switch is faulty, therefore not allowing your washer to go into a spin cycle. for safety reasons. another cause of this could be from a bad timer, if your timer stops after the agitation cycle and does not continue to count down then you have a bad timer.
Oct 11, 2009 | Kenmore Washing Machines
Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
May 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore mod 110 agitator turns while water fills tub
Check your pump and drain for a blockage.
You also could have a timer connection issue. Remove the timer wire connectors and reattach them.The timer simply has a quick connection block, sometimes they get a little loose and all you gotta do is push it all the way back in. Check for a loose lid hinge and safety switch also.
Feb 09, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
53 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
