Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
Volume pop-up When I use my monitor, the volume pop up screen comes up constantly for no apparent reason. It is very random. How do I make it stop
  • bab04e May 04, 2010
    not the case. Volume button is touch sensitive. No way it could be jammed. How retarded do you think some people are.
    Guru:
  • 1,481 Answers
May be the volume up button is jammed in the pressed position....just try pressing it and try releasing it from the current position....
Posted on May 04, 2010
How to stop the small blue volume screen from point up
There's a possibility that you have a stuck key. You can rake the keys a bit to see if that will "unstick" the key.
Aug 16, 2014 | ViewSonic VX2255 Monitor
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
The screen keeps flashing on and off.it shows the wallpaper picture for about 7 or 8 seconds then goes off for about the same time.it repeats this constantly when in a low reception area and randomly at...
This is apparently an indication that an application is running. I found that Messenger was running for some reason (I never use it) & once I turned it off, the flashing stopped. Check for running applications.
Dec 19, 2010 | Sony Ericsson Zylo Cell Phone
Phillips 170B volume adjustment bar automatically pops up
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert.
Hope this solution has been helpful?
Jul 20, 2010 | Philips Business 170B 17" Flat Panel LCD...
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
Jun 23, 2010 | HP w1907 LCD Monitor
Initial setup screen pops up at random times. The
The ability to control volume is often lost do to dirt or wear internal to the remote control. If that's the case then I would try a new remote. I universal one will give you the capacity to control volume, on/off and channel change. Try one of those (you need to program it for your individual model) and if that controls the volume you should replace your remote.
Concerning the spontaneous activation of your on screen display is also possibly coming from the remote. Put the remote in cardboard box or anything non translucent and see if that stops the problem. If it does stop it's the remote. If not your set will have to be seen by a professional electronics technician that hopefully is familiar with TV circuitry.
Apr 16, 2010 | Sony Televison & Video
Monitor goes into sleep mode at random
Check your power options in your control panel - default is usually 20 minutes to put monitor to sleep - you can adjust the time there. The monitor itself does not usually have this as a function so I would start there first.
Mar 25, 2010 | HP w1907 LCD Monitor
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Dec 23, 2009 | HP 22" Widescreen Flat Panel TFT LCD HD...
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
Jan 19, 2009 | HP f2105 21" LCD Monitor
Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
465 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Paul Bade
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
