Question about Whirlpool Duet GHW9150P Front Load Washer
Won't drain and spin. Thinking maybe if there is a button trap, it may be clogged Is there? and how do you access it? Already cleaned drain hose. Also makes noise when trying to spin water out.
    Genius:
  • Whirlpool Master
  • 1,466 Answers
You need to clean the filter ....its located bottom r/h side..it unscrews anti.clock wise to remove and clean. sounds like a coin is in it...
Posted on May 04, 2010
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Washing machine not draining
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Oct 02, 2012 | Washing Machines
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Washer won't spin
Hello.
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drain pump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breaker at the home service panel...safety first**
1) Open the small square plastic door at the right bottom of the washer.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works as well.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting our site please take a moment to rate the in foprovided for you here.
Thanks.
Sep 30, 2011 | Washing Machines
70series won't spin or drain
Hello.
If your washer is indeed a WFL2066, than the not spinning is directly related to the unit not draining.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works aswell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or yourwasher detergent and inspect inside the pump for any other foreignobjects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Beforeclosing up the small access door, run a short rinse spin cycle to check forleaks.
Thank you for visiting our site please take a moment to rate the infoprovided for you here.
Thanks.
Sep 30, 2011 | Kenmore Washing Machines
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
188 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
