I have bought an item called Automailer to mail out mass emails I'm trying to send out emails with this product's built in SMTP Server, but they always come back as failng I also tried to send emails using the SMTP Mail server, as my internet provider is AOL I was sent the outgoing mail server and switched the port to 587 but it was still unable to send anything My method of saving my mailing list so I can email them out is by using Comma Separated Value (.CSV) or Tab Delimited (.TXT)using Notebook or Microsoft Excel I have noticed that whenever I save on Excel CSV a notice appears saying that there are certain features that are incompatible and that by saving I am leaving out certain features, but once I save the document I can't identify what features has changed if any. I have Microsoft Excel 2007 by the way
  • 2,427 Answers
Ok for excell it seems you have the filke type set wrong..
click The menu (big one to top left with office symbol) then save as.. select excell 2007 workbook (top one) that will cange the format and resave the file..
for your emailer..
you need a pop 3 / smtp server.. ensure its set up propperly,, firewall aint blocking it and your crudentials are correct..
Posted on May 05, 2010
I cannot retrieve my mails or send emails, what is it
do you have an internet connection ? what email program ?
Doing a little detective work can save you a lot of extra hassle. If you're having trouble sending email from clients like Outlook, Eudora and other POP3/IMAP software, please check the following issues:
Correct Passwords
Verify that all password information is correct.
We get many requests that simply turn out to be a password error.
When cutting and pasting be sure to watch out for extra spaces.
Mail Server (SMTP) is Offline
Your server could be running and serving both POP3/IMAP but not providing SMTP service. On many systems, the program responsible for POP3/IMAP is not the same as the one for
open an email click tools accounts mail then on the right select properties you should see your email adress then click on servers you will see
POP3 should have mail. with your provider ie: mail.bigpond.com
and outgoing mail the same mail.bigpond.com
SMTP. As a result, you may be able to check mail but not send.
Try restarting your server or email service from your control panel.
ISP Blocks
An increasing number of ISP's are blocking port 25, the port used to send email.
Many of the major ISP's, including NetZero, MSN, Earthlink, AT&T, Comcast and Verizon, block port 25 in an attempt to control spam. If your ISP blocks port 25, then you will be unable to send email out of your server.
This is not a server problem but a direct block by your ISP. We can often work around these blocks by configuring your mail server to listen to additional ports.
You can test if port 25 is blocked by using a telnet client to connect to port 25.
If you connect successfully to port 25, you will see your mail server's banner.
This will list some information about your mail server.
If you cannot connect to port 25, then either your mail server is down or your ISP has block port 25.
ISP blocks are becoming an increasing problem.
Generally, once password issues have been ruled out, sending email is all or none. If the mail server is down, no one will be able to send email.
ISP blocks will only impact those clients behind that ISP's network.
Server Load Throttling
Many SMTP servers will begin to reject email if server loads are too high.
If you have root access, you may want to login and run "uptime".
This will tell you your current load averages.
Many systems stop responding to email requests if loads exceed 12 for a five-minute period.
If the load does not decline to below 4 within a few minutes, then you may have a service performance issue.
SMTP Authentication
Most email servers use one of two mechanisms to determine if a user is permitted to send email.
The first method, "POP before SMTP", requires that the user first check their email before they can send.
If a user cannot check their email, then they will not be able to send.
Try restarting your POP3/IMAP server and testing again.
The second and preferred method is called SMTP Authentication.
This method should be used if your system supports it.
Current Ensim, Plesk and cPanel servers all support SMTP AUTH.
To use this feature, the user must check configure their email client to use authentication for sending mail. In Microsoft Outlook, there is a check box called "This server requires authentication."
That box should be checked.
hope this helps
Sep 17, 2012 | Dell Latitude D 600/610
0send/receive showing 0 of 52 task completed?
hi!!!!!
may be there is a problem in your ISP
so try to resend it
or try to zip your jpegs file and then sen it to email!!!
Sep 21, 2008 | Computers & Internet
Cannot send email but I can receive email. What is the problem? Yahoo email
Hello, ''Wanda'' sorry, for your problem. If you're able to receive but unable to send mail using your POP mail client (such as Outlook), please review the possible troubleareas below. SMTP Server In the fight against unsolicited commercial email (spam), some Internet service providers require their subscribers to send mail through the ISP's own SMTP servers. If you experience problems sending email, please contact your ISP to determine if it requires different SMTP server settings. Youwill need to use the ISP's SMTP server in place of Yahoo!'s SMTP server when configuring your POP mail client. The following is a partial list of ISPs that require you to use their SMTP servers. If your ISP is among them, try replacing the Yahoo! SMTP server with the ISP server in your POP mail client settings, or consult the ISP's help files. If your ISP does not appear in the list below, please contact your ISP directly for more information. Thanks
Oct 01, 2011 | Yahoo Mail
Can recieve e mails,cannot send or reply to in-comming mail.all messages come up as failed delivery.no problem when first connected
1. Change the settings in your email software so that the email account you're using designates an Outgoing Email Service that your internet service provider won't block. Your internet service provider should provide you with the address of an acceptable Outgoing SMTP Mail Server. This information is often listed on their website; if it isn't, call their technical support and ask them the address of their Outgoing Email Server. Then go into your email software and change your current Outgoing SMTP Address to the one your ISP requires.
2. After you designate a SMTP address not restricted by your ISP, you may still receive the following error:
Port: 25, Secure(SSL): No, Server Error: 530, Error Number: 0x800CCC78
Now you are reaching the Outgoing SMTP Mail Server, but it won't process your request without further authorization. You will need to go into your Email Software and find the setting that indicates that your Outgoing SMTP requires further authorization. Select this setting and enter the username and password required by your ISP (or reqired by who ever is the administrator of the Outgoing SMTP Mail Server that's not blocked by your ISP). For example, at the time this article was written MSN Internet Service's SMTP Address was: (secure.smtp.email.msn.com). However, this email server won't allow you to use it unless you send your MSN username and password along with your request to send email.
Feb 22, 2010 | Computers & Internet
I cannot send mail on my MacBook Pro (Intel) using OS X's Mail program at home using my 2wire; it works at the office on Cable. What's wrong with my settings and is it software or hardware?
You may be using the wrong SMTP address for the Outgoing mail server address for your email service.
If you are not sure what your SMTP Outgoing Mail Server address is, then you can reference this link
below, to locate the Outgoing mail server address of your current email service provider
Link: POP & SMTP Email Server Addresses
In regards to checking your mail settings in Mac OS X Mail you will need to perform these few steps:
*Launch Mail
• Click on Mail name and select Preferences from
the drop down menu.
• Now select the Account tab.
• Locate your affected email account from the side
bar and from Account Information, make sure
your Outgoing mail server address is correct.
I am using a .Mac account as an example,
but the same principal applies.
Now if you do find that the Outgoing mail server address for your email service is correct, then the issue may be with the SMTP server for your email service.
One way to determine SMTP functionality however, is to go online and use the web mail page for your email account and send out a test email.
I would also recommend you make sure your Macbook Pro also has the most current version update.
Apple usually has bug fixes in each of their version updates for the Mac OS X Mail application, as well as other built in Mac OS X applications.
If you are still unable to send outgoing mail, contact your service provider to get more assistance and have them check your SMTP server address, authentication and connection with their Outgoing Mail servers.
Regards,
-Mactechtrainer
Feb 01, 2010 | 2wire (1000-000057-000) Modem
I want to send an email when a blue window pops up but dont know if my yahoo is pop3 or imap server? i also need incoming and outgoing e-mail server HELP
Incoming mail server settings
•POP server: plus.pop.mail.yahoo.com
•Use SSL
•Port: 995
Outgoing mail server (SMTP) settings
•SMTP server: plus.smtp.mail.yahoo.com
•Use SSL
•Port: 465
•Use authentication
•Account Name/Login Name: Your Yahoo! Mail ID (your email address without the "@yahoo.com", for example, “testing80”)
•Email Address: Your Yahoo! Mail address (for example, testing80@yahoo.com)
•Password: Your Yahoo! Mail password
Troubleshooting tips
If you still can’t send Yahoo! Mail from your mail program, you may be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try setting the SMTP port number to 587 when sending email via Yahoo!'s SMTP server.
Your email program gives you the option of either deleting your Yahoo! messages from the Yahoo! server after downloading them into your mail reader, or leaving them on the Yahoo! server so you can see them online in your Yahoo! account, too.
Jan 19, 2010 | Yahoo Mail
No email can not be sent or compuse or reply
After deleting and recreating an account in Mail, you might not be able to send emails even if you can receive them. When you try to send a message, this alert may appear:
"Cannot send message using the server smtp.xxxxx.com"
This happens if the Simple Mail Transport Protocol (SMTP) server, used for outgoing messages, was incorrectly entered with the first account even if it was correctly entered for the replacement account.
Products Affected Mail
Resolution You should first verify that the network connection you're using is the correct one for the ISP that you want mail to communicate with.
  1. Open Mail.
  2. From the Mail menu, choose Preferences
  3. Click Accounts.
  4. On the Outgoing Mail Server (SMTP) pop-up menu, choose Edit Server List.
  5. Delete all entries for the SMTP server that is mentioned in the error, and click Done.
  6. Configure the current SMTP server by clicking Server Setting.
    Note: If you need to use multiple SMTP servers for multiple Mail accounts, see this document.
  7. Send a test message to your email address.
Jun 02, 2009 | Yahoo Mail
Can't send email from Outlook Express
remove the incoming account settings from outlook express > tools > Accounts > Mail > Prpertes under advanced tam remove the incoming port numers
work arround if you want to recieve mail
Dec 25, 2008 | Compaq Presario 700 470024-192 Notebook
Using thunderbird mail program on lap top. can receive e-mail, but can not send e-mail on any public wi-fi connection. error message says can not connect to mail server on port 25.
most isp blocks port 25 for sending out mail that's the reason you cant send out mail, ask you wifi(ISP) smtp settings and you need to set it on your smtp server so you can send out mail using thier smtp as outgoing server.
OR ask you email provider about your webmail address and manually send out mail using the web interface of your email hosting.
btw have you try to change you smtp port to 587 sometimes it work.
Nov 12, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
