Question about Fuji FinePix E500 Digital Camera
FinePix E500 Camera wont power up! instaled new batts etc but to no avail! When i turn it on, the green light comes on for a second and there is a twitching of the lens then nothing, Can someone help me PLEASE!
  • 3 more comments
  • jserv Apr 10, 2008
    mine stopped too! The lens is stuck in the out position. I dont have any light though. Tried new batteries too.
  • Hernandez187 Apr 19, 2008
    I am having the same issue.. i go to power up the camera and it twitches as it is about to start up but nothing. Need help!
  • nbrinson10 Sep 01, 2008
    im having the same exact problem!
  • jaque-en Jan 14, 2009
    Try to turn it on & the green light flicks on & then off again & you can feel the lens is trying to open, didn't drop it, bash it or anything at all~I erased some pictures then it turned itself off & that was it~tried holding the back button at same time as turning it on to no avail..new batteries...help!
  • Anonymous May 12, 2009
    same exact thing, if i hold the menu button, sometimes light stays on longer, but never any light from display, and the lens twitches, but never opens, we dont think it was dropped. batteries are fine.
Something interesting...
if you hold down the back button while turning it on it beeps and the screen flashes black.
what i would sugjest doing
would be to open her up if you are skilled with electronics and see if something got knocked loose.
mine went bad when it was dropped.
maybe something is loose.
hope i helped...
Posted on Dec 15, 2008
I'm having the same problem!!what do i do!!
Posted on Oct 31, 2008
6ya staff
SOURCE:
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
Camera turns on then off immediately
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
When i dock my camera it just won't charge. green
Remove the battery
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare Z760 Digital Camera
Finepix E500 communication problem
I have the same problem. I got a work around by changing the settings of USB connectivity to that of card. you will be able to download images but not video files. The camera will continue show communication error but at least you can get your pictures!
Mar 17, 2008 | Fuji FinePix E500 Digital Camera
FUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
Nov 13, 2007 | Fuji FinePix A360 Digital Camera
Shuts off when I zoom or take photo
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Aug 25, 2007 | Fuji FinePix E500 Digital Camera
Help
Time for a new camera.
Jul 20, 2007 | Fuji FinePix A360 Digital Camera
Photo preview problem
do you think you broke the switch when it landed mysinse wont come out on my camera so i finally took it apart you know what i found a small watch battery on the circut board maby yours got docked when it fell i wonder how many people have dead batteries and cant figure out what is wrong with their cameras
Apr 23, 2007 | Fuji FinePix E500 Digital Camera
Fuji FinePix E500 Digital Camera Logo
116 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
