Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
DISCHARGE LINE ICE MAKING
A split air conditions making choukup ?
  • Dan Webster
    Dan Webster May 11, 2010
    You have dirty coils/filter OR you simply need to turn the thermostat down at night. This time of year evaporators freeze over with the nightly temp drop especially if the air filters are dirty.
  • 674 Answers
Check you air filters and make sure the blower is running. If everything is OK the refrigerant charge maybe low.
Posted on May 04, 2010
Why is my ice machine in my fridge not working at all
THE WATER LINE MAY BE BLOCKED. IF IT IS RUN BY A COMPUTER CHIP THAT CHIP MAY HAVE STOPED WORKING & NEEDS REPLACED. THERE COULD BE A BENT IN THE HOSE SOME PLACE. THE MECHINIZUM INSIDE ICE MAKER COULD BE BROKEN OR NOT MAKING CONTACT. IT MAY BE THAT IT'S JUST GOTTEN TO OLD TO WORK & NEEDS REPALCED.
Feb 02, 2015 | Frigidaire Fridgidaire Mini Split System...
Water leak
The most common reasons for water leaking from the unit are:
1- Condensate drain line clogged, needs cleared.
2- System is freezing up, causing excessive water to overflow, check filter, fan motor, thermostat, and batteries.
If there is ice on the lines on the indoor or outdoor unit, the system is frozen. If it's a charging issue, make sure system is thawed completely before calling anyone. They will not be able to do anything until system is thawed out and will cause you to wait longer.
Sep 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Coolin coli making ice, his filter and coil as clean,out side tempreure is 03centg. can u explain(details) me about gas charging.
You can't charge on cool mode as your indoor temp is very lower than minimum temp of air conditioning. ., 16 C degree. And also due to low ambient temp your coil is getting freezes. Keep in heat mode and check still icing your coil, it's short of gas. And that time you can do gas charging by keeping cylinder up right. Helpful?
Jan 08, 2011 | Mitsubishi MSZ-A15NA Split System Air...
My split type lg air condition is not cold totally.
Check compressor is working. If yes, touch the discharge line for warm feeling. if no warm means no gas.Find out leak an arrest and then charge gas.
Dec 26, 2010 | LG Heating & Cooling
My air condition blocks some ice in the system, causing not enough cool provide.
Water leak /Icing in your evaporator is the common problem in split airconditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4.Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replacemotor capacitor.
Dec 18, 2010 | Heating & Cooling
Unit not cooling well both suction and discharge lines cool dischrcharge line [ small line] sweating
the "Discharge" line sweating on a mimn split is normal all of the flow metering is done in the outside unit . as to it not cooling well are the filters clean? if they are you more than likely have a leak and need to get is serviced
Jun 12, 2010 | Fujitsu 18C1 Air Conditioner
Bon-Air mini split 1.5 ton, suction and discharge pressures are equal. discharge valve has ice on it. and the suction and compressor are very hot.
Sorry to sat but the tech has no idea what he is doing. The metering device is in the discharge valve, making that line a low pressure, not high. If the "suction" line is hotthen it is running in heat mode.
Jun 25, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Ice maker makes small cubes
Check or change the water filter, leading into the machine.
If that is not the problem ,disconnect the water lone from the machine and see if their is sufficient flow comming through the line.
Oct 19, 2008 | Frigidaire FRS26R4A Side by Side...
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
115 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
