Question about AEG B1180-4 Electric Single Oven
Hello. I have an AEG electric oven which is
Hello. I have an AEG Competence B1180-4 electric oven which is aproximately 5 years old. It has recently stopped working and I've no idea why. The grill still works so we've been able to establish that the thermostat is working too. When you turn on the oven, the fan and the lights come on but the oven fails to heat up. Any ideas/suggestions would be appreciated.
Regards
Brad
  • 269 Answers
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
Posted on May 09, 2010
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
when i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
May 26, 2011 | AEG B4101-4 Electric Single Oven
Where is the model no on our aeg white double oven competence about 8 years old
Open the door, usually engraved within the door panel. Either on the sides or Top.
Most important number is called the PNC. If not found there, look for a sticker on the Oven Cabinet upper, after opening the door.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | AEG Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Jan 04, 2008 | Ovens
AEG B1180-4 Electric Single Oven Logo
598 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De GO PATS
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
