Question about Tomtom GO 300 GPS Receiver
HOW TO GET LOST DETA BACK ON MY TOMTOM GO SD CARD
SOURCE: Lost my tomtom one SD card
torrent maps from thepiratebay.org
Posted on Mar 11, 2008
E61N
  • 515 Answers
SOURCE: red cross on new sd card
Go to:
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Follow instructions...
Posted on Apr 11, 2008
SOURCE: TomTom One map download process
baho
Posted on Dec 02, 2008
  • 7 Answers
SOURCE: Maximum SD card size for TomTom ONE XL
The XLS which is not that much different and supports 4Gb as used in mine which allows me to keep maps of the US,Canada, UK, and the whole of europe on it and swap at will. I bought a cheap generic one. I do kow that those cards that use micro sd can and do have problems so best to avoid the micro type unless your device takes those specifically
Posted on Apr 02, 2009
  • 58 Answers
SOURCE: When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Posted on Jun 14, 2009
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
Update download for tom tom xxl 540s is too big for unit, lost all maps
Theres good news for you, you can get a SD card for your tomtom, and all you have to do is to install or download your maps on the SD card then fix it into your tomtom and you will be able to view your maps from there. For the lost maps, connect your tomtom to your computer, be sure to have your drivers software, then you select your tomtom form your computer, then you install all lost maps back on it by restoring all old maps. But for large downloads, download all new maps on a SD card. That should do the job.
Hope this information came in handy.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Red cross on sd card on startup
You can not use a sd card from one TomTom and put it into another TomTom. The operating system on the card is coded for each individual TomTom device. First try doing a reset with the card installed on your dads TomTom. The reset hole is on the bottom of the TomTom marked reset Use a streightened paper clip, insert the paper clip into the hole until you feel a click then hold it in for 20 seconds. If that didn't work and you have a card reader insert your dads sd card into the reader and make a backup of the everything on the sd card. Just copy and paste everything on the card to a folder on the desktop you have created on your desktop. Next delete everything on the sd card EXCEPT the maps and ttgo.bif or ttgo.bak file. Now that you have made a backup and deleted everything on the sd card except for the maps and ttgo.bif or ttgo.bak open TomTom Home. TomTom Home should see your card and install the operating system back onto the sd card. If it doesn't you may have to insert the sd card back into your dads TomTom and connect it to the pc. It may take a few times of doing this to get the latest operating system back onto your dads TomTom. You can do the same for your TomTom, but you cannot use any thing bigger than a 2 gb sd card. Do not get sdhc cards they won't work. This will only put the operating system for your TomTom onto the sd card. When you have installed the operating system onto your device it will say "no maps found", you will have to buy the map from TomTom..
Jun 17, 2009 | Tomtom GO 300 GPS Receiver
I lost my SD card for my Tomtom One.
Hi, Here's a link where you can buy another SD card. Good luck. If this helps plz rate this 'fixa'. If you need more help leave a comment, I'll be happy to help. Thank you kindly.
http://www.activegps.co.uk/tomtom-one-maps.htm
Feb 13, 2009 | Tomtom ONE GPS Receiver
Tom tom sd card wiped clean
more than likely, I just purchased a new tomtom sd card on ebay with all the new maps on it, ver.7 got it for a UK seller no problems, did you back it up on your computer? hopfully you did, then you can just connect it to tomtom home and reinstall it.
Oct 11, 2008 | Tomtom GO 300 GPS Receiver
Lost all maps
I am very sorry to hear that you had no backup. Theres no way you can recover data once you have deleted it from an sd card. BUT , If you still have the authorisation card ( thats the one that generates the activation code ) then you might be able to copy data from another tomtom card to your card then reactivate it with the authorisation card. GOOD LUCK.
OTHER TOMTOM USERS NOTE: Backup your SD Card.
Jun 01, 2008 | Tomtom GO 300 GPS Receiver
Mar 08, 2008 | Tomtom ONE GPS Receiver
Tomtom 1
You cannot use a sd card from another tomtom. The sd card is coded for each individual device. About the only thing you can do is to purchase a 1 gb card (no larger because it won't be supported). Insert the blank card into your unit and connect it to your pc. Go to my computer and see which drive the tt is. format the card and then open tomtom home. This will load your operating system back onto your card. I don't know if you can download a free map or not. Check the tomtom forums for more information concerning maps.
Hope this helps
Oct 13, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 300 GPS Receiver Logo
27 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
