HP printer AC power adaptor 0950-4399
NO DC o/p at the output pionts of Adaptor. Opened the adaptor I get DC approx 300 V up to the switching transformer primary points. Secondary pionts no voltage. o/p voltage is +32V & +15V. Can anybody help
    Problem Solver:
  • 21 Answers
I just get one from www.order-bulk.com my print is working now
Posted on Nov 19, 2009
Since I could not find the fault and the new HP ac adaptor was very expensive I made a dual voltage ac adaptor with transformer and regulated DC o/p. It cost me much less and till date Its working just fine.
( The all expensive HP original adaptor was available with just 3 months warranty.)
Posted on Oct 06, 2008
I want to purchace new HP printer AC power adaptor 0950-4399 from mumbai where shall i contact
Posted on Oct 04, 2008
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
0xc190003 HP b010
"Gondo" <nowingspaanspam@yahoo.com> wrote in message
news:fsv880din9khpu7e9p8olvrc8uj1u1uj3o@4ax.com...
> This has been an ongoing problem with this laptop, and now I can
> hardly get it to power up at all.
> First, the AC/DC power adaptor jack in the back is very loose and
the
> power is lost intermittently when you move the jack around on the
> receptacle.
> Once the green power light does come on, you press the power switch
> repeatedly to the left to turn the laptop on and nothing happens.
Only
> by the combination of wiggling the power adapter jack around while
> pushing the power button repeatedly can you maybe get lucky and get
it
> to start up.
> I was just wondering what else might be bad internally besides the
> power adaptor jack. Possibly the connection to the power switch or
the
> switch itself? The AC/DC adaptor was replaced recently, so I'm
pretty
> sure that isn't the problem.
> It appears it will need replacement parts, so I'm looking for
> recommendations on where to find the applicable parts online.
To Fix Your Hp Issue,In Case You Still Having Problem Then Follow Us For On : HP Support
Feb 26, 2013 | HEWLETT-PACKARD Hp Ac Adapter Power...
Which AC adaptor to use with New Balance Elliptical 9.0e
if u have a lot of ac adaptor then find thesame voltage output to ur gadget..if you don't have the exact voltage dc output for ur gadget better buy one....what is your machine need? ac power or dc power? if your machine is electronicaly operated so u need is dc power...but if your machine is like a motor so u need is ac power....tnx
Jun 19, 2012 | Computers & Internet
My remote speaker system works with the batteries but not with the AC adaptor plugged in to the speaker.
I would suggest to check AC outlet first where adaptor is pluged in,if Ok measure output voltage from adaptor to see if there is any (using any voltage multimeter with AC/DC)
Check label on adaptor shold be writen AC or DC output ,and value 3V,6,9,12,24,48 etc...
If adaptor is ok then problem is power jack mounted in to the speaker (cold solder joints' or damage)
Aug 23, 2011 | Audio Players & Recorders
How many volts does a HP Pavillion TX1410 adaptor has?
Please look carefully at the unit, the ratings are on the outside of it.
Oct 21, 2009 | HP Pavillion ZV6000 Notebook
Trying to get the laptop to just work on power not battery.
Plug in your power cord from the laptop to an electrical outlet. Your battery is dead and/or needs recharged.
Apr 14, 2009 | HP Pavilion ze4125 Notebook
AC Adaptor Model No SA3025/37
ok go to wal-mart and for 7-12 bucks get a "universal" ac/dc power source....look for the one that has the usb output and buy that remeber to set it at 5 volts or you'll burn up your mp3 player....other opt is radioshack for 20 bucks and get a wall plug ac/dc - to - usb power source... same thing more money....
Dec 12, 2008 | Philips SA3025/37 Flash MP3 Player
COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
Aug 27, 2008 | Compaq Presario R3000 Notebook
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
512 people viewed this question
k24674
jasbo
jasbo
