Question about Malber WD1000 Front Load Washer/Dryer
It seemed like something small came loose in the back of the machine, I could hear it. Now, everything works EXCEPT the barrel doesn't move. It doesn't agitate, spin, nothing, it just doesn't move since I heard that "piece come loose. I'm in Maine and have had ZERO success locating a Malber technician.
    Genius:
  • Malber Master
  • 1,474 Answers
Check that the belt has not fallen off or drive shaft not loose bolt...
Posted on May 04, 2010
Iha a Whirlpool 852592-a model washer. everything work except the spin cycle. when the spin does not work you can open the lid and move the basket around and it will work for a while. What can it be?
It may be belt driven, if so then the belt is too loose and must be tightened or replaced, or maybe a belt pulley is loose, you should be able to hear squeaking or some other noise if the belt or pulley is loose but maybe not.
Mar 12, 2018 | Whirlpool Washing Machines
Space bar on sylectric 2 ibm typewriter is not moving the type
There are a few things that can cause your spacebar to not move the carrier. Do you hear any sound when you press on the bar? There are adjustment that may need to be made to the machine or perhaps there is something sticking in the mechanism. Unfortunately you mey not be able to fix this yourself as these machines need a technician to properly repair and service the machine.
Feb 15, 2015 | IBM Correcting Selectric II
What would cause my Kenmore washer not to spin. I have replaced the MCU and still have the same problem. the door locks and the lock light comes on. All connections seem to be good. The drain at the bottom...
I would take the back off the machine and check the small 5mm censor pipe that goes off from the bottom of the drum and blow gently into it if you hear a click and one when you release the air then clean the small metal pipe where it goes on with a pipe cleaner or something similar as sometimes this pipe is only partially blocked not allowing the censor to react fully causing the problem
Dec 22, 2017 | Washing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
My needle keeps breaking. So I unthreaded everything and cleaned the bobbin area. Per the manual i rethreaded everything but when i get to the part of turning the balance when toward me until the needle...
check to make sure the needle is inserted correctly--flat side to the back of the machine
that the needle is inserted all the way up in the needle shaft
check the needle clamp screw to make sure it's not loose
is the needle correct for the fabric that's being sewn
check to make sure the needle is not hitting the needle plate- if it's hitting the needle plate or the bobbin case then it's possible the machine is out of time & would have to be serviced because they have the proper tools to time it
Aug 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
It runs fine during most of the cycles except the spin cycle. It is almost like the barrel is not fastened down but i have checked the springs and they all seem strong and tight. When it goes to spin, the...
Could be bearings, the powder is possible Concrete weight / check this is not loose first , give it a good shake/ check for loose securing bolts,,Good luck
Mar 03, 2011 | Washing Machines
Hi, I recetly purchased an X-700. Every thing seems OK except that the shutter speed control knob seems loose. I mean it works allright but can move up and down, can tilt .... I dont know if how to...
There's a little silver ring on the inside with two little notches in it. try putting a toothpick or something small in one of these notches and turning it to the right to tighten it.
Jan 02, 2011 | Minolta X-700 35mm SLR Camera
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
96 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
