I've replaced the 4 AAA batteries and the smaller battery at the same time since the calculator kept turning off. Now the claculator is staying on, but the cursor is not blinking and it takes a long time for it to register that I've typed anything. I've been hitting "enter" yet not value appears and it won't register that command. I can't even turn it off without taking out the batteries. I'm a middle school math teacher at an alternative school and I really need this calculator to teach my students. We have no money to purchase new calculators and I just don't understand what could be going on here. I've never seen this before. Is there a way to connect it to the computer to fix it or is this one a "gonner"? I've had these TI-84+ calculators for about 3 years.
Thank you for your time!
I've had this issue
before with my TI-83 Plus. I'm not sure exactly the solution I used, but these
steps progress through the mildest to most extreme methods of fixing the
calculator.
Solution 1: Take the batteries out.
Odds are you've tried
this already, but it bears mentioning.
With the calculator on,
remove the triple A batteries housed in the back. After a few seconds, replace
them and turn the calculator on.
Solution 2: Clear the RAM.
Remove one of the AAA
batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the
AAA battery and then turn the calculator on. The calculator should display the
message "RAM Cleared". Release the [CLEAR] key and then press it one
more time to remove the message.
Solution 3: Reinstall the operating system
batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA
battery and then turn the calculator on. The calculator should display "Waiting...Please
install calculator software now"
Here is the website to reinstall your OS.
First you'll need the TI-Connect
software.
Solution 4: Remove all sources of power. This is a risky move, but if your
calculator will absolutely not work after you try even reinstalling the
operating system, it might be your last hope.
Remove all of the batteries
including the round lithium battery for 5 minutes. After the 5 minute period,
reinsert all of the batteries and turn the calculator on. Adjust the contrast
if necessary.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1). Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system. Try a new set of AAA batteries. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
(Procedure 2).
~Connect the TI Connectivity cable between the PC and the calculator.
~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
~Connect the TI Connectivity cable between the PC and the calculator if you haven't already.
~Follow the on-screen directions to reinstall the calculator's OS. When or, if the calculator install the fresh OS goto step 4.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If the above process did not work to turn your calculator on, try re-doing the above process. Next time extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
If the above process did not work. Try re-doing the process and, extend the time in step 4 by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
Oh my! It worked! THANK YOU SO SO MUCH!!! I greatly appreciate your help!!
Sincerely,
Nicole (greatful math teacher)
Glad to be of help.
Try a hard reset. Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries and turn the calculator on.
Does this do any good?
